Your Plastic Painting Procedure?
Range Rover Classic
I'm replacing an Impact Strip. Since its not a huge piece I thought I could get away with rattle cans. Anyone have experience with it? And any particular brand of primer to go with?
2004 C32 ///AMG
let dry between coats
a few coats of primer, a few coats of paint and finally a few coats of clearcoat.
Originally Posted by NorCal124
Make sure to wash and dry what ever you're painting. Some light sanding and cleaning between primer, paint, and clear doesn't hurt either.
The key is to be patient and not overspray. Drips will ruin the project. Do thinner layers than you think you should and just do lots of them.
Dora the Explorer
W124
I can understand sanding between primer and paint. But between paint and clear?? I wouldn't recommend that, unless it was wet-sanded with an extremely high grit... Even then, I'm not sure what the point would be.
