code reader
Old Jul 9, 2006 | 04:00 AM
oneill_1's Avatar
MB 300E | BMW M Coupe
code reader
so i my check engine light has been on for awhile now and i just decided to make that code reader to try and figure out why the light is on. i found that thread that shows how to make that contraption but it really doesnt explain how to use it....here comes my question:
anyone out there know how to use it? where do i put the positive banana plug? negative banana plug?
it would be great if anyone know how to use it....let me know if any of you have had any experience.
BTW, i have a '93 300E-2.8ltr that supposedly had some system that makes it easier to read the codes if that helps anyone...
Old Jul 9, 2006 | 05:18 AM
battlecat714's Avatar
a TVR Cerbera Speed Twelve
Reading Fault Codes
- Turn ignition key to “on” position, all dash warning lights will be on.
- Remove cover on 16 plug diagnostic connector near battery.
- To read check engine light codes (DM), hold down built in button next to LED light for 3 to 4 seconds, LED light should be on, release button, count the number of LED flashes that follows. Hold button down for 3 to 4 seconds again to check for another code. Keep doing this until all codes have been read and first code comes up again.
- To clear codes - hold down button for 10 to 12 seconds, turn ignition key off for a few seconds, repeat to clear additional codes. Ignition must be turned off between each code cleared.
To check other modules using code tester – insert black plug into socket #1 (ground). Insert red plug into socket #16 (12V power). Insert yellow (third color) plug into socket to be tested, for example #8 or #14. Repeat steps above for LED button using code tester button and LED. Same process for deleting codes as with LED button.
Check appropriate fault code list to determine fault.
Checks codes as quickly as possible at the first sign of a problem. Codes spread from one module to another and will often show up twice or cause other codes. The sooner you check the codes the more likely you are to identify the source problem.
Motor Fault Codes pdf. file: http://www.yousendit.com/transfer.ph...67EE3831862721
How to build a code reader pdf. file: http://www.yousendit.com/transfer.ph...7589442CB36CAD
Courtesy of my friend Dean.
Old Jul 9, 2006 | 06:37 AM
oneill_1's Avatar
coolio.....thanks, we'll see if it works.
Old Jul 9, 2006 | 12:20 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
does that tester work for the m103 as well?
Old Jul 9, 2006 | 05:14 PM
oneill_1's Avatar
hey battlecat714,
will the codes that you provided be the same for my car since my engine is M104 and the codes are for the M103 (that is what it says when you save the file)...
Old Jul 9, 2006 | 07:22 PM
crr1612, it should work.
oneill 1, here's the list mangg.
M104 Codes:
1 No faults.
2 Oxygen sensor inoperative.
3 Lambda control inoperative.
4 Air injection inoperative.
5 EGR inoperative.
6 Idle speed control inoperative.
7 Ignition system failure.
8 Coolant temp sensor-open or short circuit.
9 Intake air temp sensor-open or short circuit.
10 Voltage at Air Mass sensor too high or low.
11 TN (RPM) signal defective.
12 Oxygen sensor heater open or short circuit.
13 Cam position sensor signal from-EZL/AKR ign. control unit defective.
14 Intake manifold pressure at start too low.
15 Full throttle Info defective.
16 Idle speed info defective.
17 CAN Data exchange-Malfunction between control units.
18 Adjustable camshaft timing solenoid-open or short circuit.
19 Fuel injectors-open or short circuit or Emission control system adaptation at limit.
20 Speed signal missing.
21 Purge switchover valve-open or shorted.
22 cam position sensor signal defective.
23 Intake manifold pressure w/ engine running too low.
24 Starter ring gear segments defective.
25 Knock sensors.
26 Upshift delay switch over valve-open or shorted.
27 Coolant temp sensor deviation between sensor ciruits 1 & 2.
28 Coolant temp Sensor.
Old May 9, 2007 | 11:31 PM
kricoperry's Avatar
Hi, I'd like to get the info on the codes and home made code reader but the files shown in Battlecat174's reply are no longer available. Can thy be reposted?
Regards,
James
Old May 10, 2007 | 12:02 AM
BenzBro's Avatar
1990 300CE, 1984 190e 2.3 (sold)
Here is link to make the thing. Use a old plastic bottle and drill two holes for the led and button in the bottom. Then tuck the wires into the bottle when not in use and screw on the bottle cap to keep all the wires together.
http://www.mercedesshop.com/shopforu...9&d=1162392878
Here is how to determine what the flashes mean. Look up your chassis #.
https://mbworld.org/forums/showpost....24&postcount=3
Old May 10, 2007 | 09:50 AM
Kestas's Avatar
95 E320 Cabriolet, 108K
http://www.mercedesshop.com/shopforu...d.php?t=107630
Old May 16, 2007 | 02:13 AM
jgajito's Avatar
1992 190E 2.6L
Thanks for the help!!!
