Possible Modifications to 1991 300ce?
I hear you, everyone has their own taste. Your best bet is to go symmic (or however you spell it) euro krystals, it'll suit your car better than the first two.
I just use Sylvania silverstars and I'm all set, no need for better light output since boston roads are like freakin christmas trees anyways. LOL
but I feel you on that HID upgrade, that would be dope.
2Phast is a genius.
Regards,
Jason
There is always a thread or two going on at mercedesshop.com tech forum about building M103 and M104 motors.
I'm just starting to learn about all this from the various forums.
I think the idea for the 300D transmission swap is cool. And there is another, changing out the differential for quicker times.
Wheels and lower profile tires will help a lot with control in the turns I should think.
Sway bars are numerous, H&R, Merc Limo bars, Sportline bars, etc.
Putting new Rubber bushings everywhere helps get the car back to original response. Replacing the motor and trans mounts and control arm bushings is a good start. Some people go with poly type aftermarket bushings. I'd have to test drive such an equipped auto to see if its a vast improvement.
What shocks and struts did you go with? Bilstein heavy Duty or Sports look good. I think there is a way to order the Sportline set-up from the Merc Dealership system and get them out of germany. Do you know about this?
Also, the AMG Generation 2 body kits are available through the dealership system also. I have been told to use the dealer with the largest Genuine parts department whose name escapes me at the moment but is located in Southern California.
I would like a European shifter kit for starters with the transmission.
And there must be an ECU chip upgrade.
Regards,
Jason
Regards,
Jason
PS the other stuff is sort of performance oriented but it really falls in the same category of parts that are overdue for replacement. I'm not concerned with resale value because as the car is now it doesn't really have any and with a few upgrades to make the car more decent it will only be worth the work put into it.
I'm taking it in right now but I hate driving around with my registration out of date.
Regards,
Jason
I love my car like no other, and I plan on keeping it till it totally craps out on me. I also would like to replace the struts, sway bars, and shocks/springs with performance parts because my car is nearing 100k and its time, like you said. What else should be replaced at the same time as all that supsension stuff I mentioned?
Regards,
Jason
I love my car like no other, and I plan on keeping it till it totally craps out on me. I also would like to replace the struts, sway bars, and shocks/springs with performance parts because my car is nearing 100k and its time, like you said. What else should be replaced at the same time as all that supsension stuff I mentioned?Limo bars are probably a dealer item.
I just replaced my muffler and exhaust pipe with OE quality (Ernst made for mercedes)
Car passed smog with flying colors. A big deal here in California.
Next up are Euro lights and transmission mount and lower control arm bushings.
Then after that it's Sportline time.
Where is the best deal on Euro lights?????
Regards,
Jason
Here's the list of parts for my car.....yours may be different......If you are interested in this upgrade,
Parts Required for 1992 300CE Sportline
Suspension (except steering box and rear subframe bushing)
Part Number Description Quantity
A 124 320 64 30 Front Sport Strut 2
A 124 320 23 31 Rear Sport Shock 2
A 124 321 30 04 Front Sport Spring 2
A 124 324 28 04 Rear Sport Spring 2
A 201 321 10 84 Front Spring Pad 2
A 201 325 09 44 Rear Spring Pad 2
A 124 323 68 65 Front Sport Swaybar 1
A 124 323 45 85 Front Swaybar Inner Bushing 2
A 124 323 51 85 Front Swaybar Outer Bushing 2
A 124 326 19 65 Rear Sport Swaybar 1
A 124 326 01 81 Rear Swaybar Bushing 2
A 201 330 01 75 Front Lower Arm Bushing Kit 2
or A 124 330 09 75 (Need VIN to determine part #)
As for the motor. There are plenty of ways to make the motor do better. Mosselman's Twin Turbo is one. It is also the most expensive. ***** pretty much designed Twin Turbos for these cars and the application is pretty flawless IF you have all the parts. Getting a used system can be a problem [experience speaking here].
Breaking down the motor, port and polishing can help. As much as we like to think Mercedes is perfect, these are Bread and Butter cars, and the motors are not precision machined. The intake and exhaust ports can use work to insure maximum air/exhaust flow, sometimes a lot. We are finding that is also true on even the mighty 500E motors. 20-30 hours of porting and polishing of the manifolds and heads are necessary to really smooth out the castings and provide “spec blueprinting” of the engine.
After that, lightweight forged pistons and Titanium ConRods will lighten up the rotating mass of the crankshaft dramatically and provide a higher revving, higher compression and MORE POWER. This is without touching the cam(s). While they are “custom”, the pistons are only about $200 each. Add the same for the ConRods and you have a lighter spinning motor for between $2400 and $3000 in new parts, depending on options.
The extra power associated with these mods, along with extra breathing [K&N] and exhaust [HiPro Cat-no resonator-performance exhaust] is strong. Seat of the pants is amazing with the light weight pistons in the bottom end. Dyno on the 1992 300E w/no Turbos goes from 177 stock to 252bhp – a little over 40%. Total rebuild costs are about $5K for the motor. That does not give the kick of the turbos but is easier and more durable. It also gives a rebuilt motor. When going with boost, it is wise to rebuild at the same time to provide the best environment for the now 280-310bhp [dyno tested]. We have not run the turbos on the hot motor since the high compression is not compatible with the turbos which actually need a reduction of compression with high boost.
I would think that should get you near 275-280 at that point. A motor built up like that would be very durable and safe, not "pushing the envelope" or testing unknown performance options.
I got much quick times out of the apex and through esses with the extra power. The end of straight speed was also enough to require a serious upgrade of brakes as I glazed the stock rotors on the fourth lap through coming down from 145.
You sound like a very valuable member for my performance-oriented questions. How does this strike you. Getting the airbox and intake setup from the 500e on my 300ce and heatwrapping it. Will this help my car breathe better and possibly assist in performance? What other reccomedations can you make for the intake?
