my wheels hate me..
I've recently lowered my car with H&R springs, Bilstein Sport shocks. The spring pads are Bump2 for rear and Bump3 for front..
Here are 2 pics... Just to give you an idea of what my car looks like..
Anyway, I discovered a funny thing after installing the new "stuff" (suspension and AMG wheels).. Before my installation, I used to run the W210 8J*17 wheels (as shown in my signature) and I experienced lots of rubbing at the top of the fender.. I got fed up and got myself some proper wheels (AMG 7.5J * 17, offset I think is 35 or 37), running 215/45/17 tires..
The funny thing is that my RIGHT wheel rubs the lower portion of the fender... As in where the two-tone bit is.. My left wheel is totally fine.. I am really confused about this
and this drives me mad as I've been trying to eliminate the rubbing problem since somewhat a year ago
... The wheels no longer rub at the top of the fender though, thank god.
Any ideas/opinions are grately appreciated,
Jeff
when I was braking heavily to avoid traffic tonight on the highway).. I can take a pic of the area where the tire rubs.. As far as I can see, it has done no damage whatsoever to the tire but I think a bit of the rubber part of the fender has been shaved OFF (you can see the metal)..Could this problem be due to me not getting alignment done after lowering the car? This is actually on my priority list but I just don't have the time to bring the car to the mech this week, or the next
Cheers,
Jeff
The amg spacer kit is way expensive for what it is. Try researching what components make it up and then go to home depot and mix and match.
Are the control arms expensive to fix? I've spent enough on the car already this month and I would hate to have to spend more
Also, should I take my car to garages offering laser alignment or are traditional methods good enough?
Cheers,
Jeff
Pete
Pete
The AMG spacer kit is just a plastic bush to hold the fender away from the chassis to allow wider AMG wheels. Any plastic bush will do.
Anyway, I cannot refrain from asking this one stupid question.. Since the alignment of my car is not right (due to maybe a bent control arm), can I run the car like this for another 1 or 2 weeks?
I tried to book the car in for the coming Saturday but my mech can't make it. I am far too busy during the weekdays to drop the car off
.. I've heard from people that this may cause premature wear to part of my new tires (maybe the outer edges may wear unevenly and quicker)..So, what is my position here? Is it best for me to avoid using the car until I get it all fixed? To describe the situation a bit, the car will not run in a straight line if I get go of the wheel but it will only pull slowly to the left.. If I want to keep the car straight, I will have to hold the wheel at the 1 o'clock position (normal should be 12 o'clock)..
Please advise as I only just got some new wheels and tires and I seriously don't want to ruin them
Cheers
