does the e230TE console fit a 95 e320?
Old Aug 31, 2006 | 12:16 PM
jdmfiend's Avatar
are they all the same? or are there any difference between the e320 sedan and e230TE consoles? i found one im going to buy ASAP if they fit.
http://www.auctiva.com/hostedimages/...s=0,0&format=0
let me know asap pleaseeeee!
THXTHXTHX!
Old Aug 31, 2006 | 12:24 PM
shadowgriffen's Avatar
is a German Tank
THXTHXTHX!
mmm....you have to be aware that some models (like euro models) have a different HVAC setting, therefore it may have different holes to fit turn **** instead of buttons...that is if your planning on buying the entire console...
Old Aug 31, 2006 | 12:57 PM
jdmfiend's Avatar
here's a usdm console from a TE
oem w124 sedan console
Old Aug 31, 2006 | 01:12 PM
is a German Tank
If the only part of the console you're looking for is the gear selector sorround then I'm pretty sure you are not going to run into any problems.
Just make sure it does not have the "HEATED SEATS" Slots if your car does not have that option.
Old Aug 31, 2006 | 01:23 PM
is a German Tank
HAVE YOU NOTICED THE SEDAN DOES NOT HAVE A VOLUME FADER SLOT???
keep that in mind...not all consoles are the same
Old Aug 31, 2006 | 01:43 PM
jdmfiend's Avatar
i have heated seats =(
Old Aug 31, 2006 | 02:04 PM
is a German Tank
See you should be that you have me around to hold your hand
Old Aug 31, 2006 | 02:28 PM
'91 300CE's Avatar
2000 C230K and 2002 ML320
That TE console is from an older car than the sedan console... they did away with the fader control in newer models when they integrated the fader into the head unit... from what I remember
Old Aug 31, 2006 | 02:46 PM
is a German Tank
Yes I believe you to be correct.
