removing side rear windows in 300te???
Old Sep 1, 2006 | 06:15 PM
AlanS's Avatar
How do I remove the aluminum trim, then the windows on the rear sides of a 1989 300te. I have to replace the gaskets, they leak and are rotting the metal underneath. Firstly, I fear bending and ruining the trim...2nd-ly...breaking the window. Other than that, I am fine.
Old Sep 1, 2006 | 08:39 PM
DarkHand's Avatar
1994 White an Grey E320 "Shado"
http://www.manualsunlimited.com/inde...Path=46_70_135
Best to get the manual for your vehicle it will give you the definite answer...
Old Sep 2, 2006 | 05:44 PM
GORBETTTEAM's Avatar
'95 3.2 M104
Removal and installation of crank window on rear door
1 Remove door lining.
2 Pull off plastic foil.
3 Remove safety bracket on window lifting rail.
4 Extend guide member from window lifting rail.
5 Lower window completely down.
6 Remove sealing strip inside.
7 Remove flexible window running rail.
8 Remove screw from window web below.
9 Remove screw on window web at top and pull out window web in downward direction.
10 Turn window in door around and lift out of window shaft in upward direction.
11 For installation proceed vice versa.
Attached Thumbnails removing side rear windows in 300te???-89328766.jpg   removing side rear windows in 300te???-89328811.jpg   removing side rear windows in 300te???-89328768.jpg   removing side rear windows in 300te???-89328769.jpg
Old Sep 2, 2006 | 06:04 PM
'95 3.2 M104
Removal and installation of electric window lift on rear door
1 Let rear window completely run down.
2 Force molding from door inside actuation, remove in forward direction and pull electric plug coupling from rocker switch.
3 Remove door lining.
4 Pull off plastic foil.
5 Open plug coupling and pull out electric connecting cables for window lift motor.
6 Expose connecting cables up to grommet on door inside plate.
7 Remove safety bracket on window lifting rail.
8 Extend guide member out of window lifting rail.
9 Set window in upward direction and protect with plastic wedge against falling down.
10 Unscrew nuts on window lift motor as well as screws on window lift guide rail at top and below.
11 Extend window lift out of locks in door inside plate and remove window lift with motor in downward direction out of assembly opening. Installation Caution: Actuate electric cable control for rear window lift only in installed condition, since it will be operational only in combination with door inside plate (risk of damage)
12 Insert window lift via assembly opening in door, while guiding the connecting cable through grommet in door inside plate.
13 Introduce lock of window lift guide rail at top into door inside plate.
14 Insert lock of window lift guide rail below into door inside plate.
15 Insert window lift with threaded bolt into door inside plate and fasten.
16 For further installation proceed vice versa. Note: Connect the electric cables provided with numbers to plug coupling, making sure that numbers are identical.
Attached Thumbnails removing side rear windows in 300te???-1.jpg   removing side rear windows in 300te???-2.jpg   removing side rear windows in 300te???-3.jpg   removing side rear windows in 300te???-4.jpg   removing side rear windows in 300te???-5.jpg
Old Sep 2, 2006 | 06:06 PM
'95 3.2 M104
the rest of the pictures...follow up 13th step thru 16th
Attached Thumbnails removing side rear windows in 300te???-6.jpg   removing side rear windows in 300te???-7.jpg
Old Sep 2, 2006 | 08:13 PM
DarkHand's Avatar
Excellent information!...big ups for the details!
Old Sep 2, 2006 | 09:21 PM
Ron in SC's Avatar
99 ML 320, 97 Porsche 993 C2S, 92 300E
Yes it is, but he's talking about the windows in the cargo section of his 300TE wagon.
Old Sep 3, 2006 | 10:43 AM
'95 3.2 M104
Red face
ooops no info on that... I guess the only way is to talk to "the glass guys". I think they need to cut-it-out and install it back with new caulking(I think )
