Interior Repair and Suspension questions
Old 09-05-2006, 11:30 AM
sinos's Avatar
I have an 95 E320 that is mostly in good condition. However, the panels that cover the C-pillar on the inside have started to come loose. I assume that it is held together by some adhesive but wanted to make sure what kind to use. Can anyone help?
Also the plastic on the power seat controls have started to warp. Have any of you faced this problem? What's the remedy to correct this?
In addition, a lot of you have installed limo swaybars or E500 swaybars to improve the grip and handling. How much are these and where's the best place to source them? Thanks.
Old 09-05-2006, 05:23 PM
YNVDIZW124's Avatar
lots of cars
Pretty easy repair on the c pillars just remove them, slide the seat foward, remove the two screws on the lower plastic cover, remove the seat belt, remove the windlance on the sides, pop it off from the top, and remove the vinyl. If you can try to go to an upholstery shop and buy some new vinyl that matches your interior and recover them using 3m super 77 glue.
Quick Reply: Interior Repair and Suspension questions
