Torque Converter
If you have removed the 6 TC retaining bolts and still having difficulty getting it off .. that will be because the TC has a centre spigot that is a close fit into the flywheel centre....over the years the 'close fit' becomes a 'tight' fit due to rust/corrosion and will therefore require you to gently lever the TC off the flywheel (have another pair of hands to support the TC whilst you use two levers to 'rock' it loose).
My opinion is that if a member posts a problem on a public forum such as this and as a result receives helpful/useful advice then it is common courtesy to at least acknowledge any helpful replies.
Regards.
Some peeps come on here and register to become a member only to get a question answered then Bail never to return again.
what can you do, you know?
I won't list my excuses - you are correct
Needless to say I have not accomplished much on my project - Higher priorities keep popping up and sucking the money away....Good thing the old benz is not needed immediately.
But I do thank you all for your advice. Alphonsohall you were not kidding about the "tight fit." It took some pursuasion but got it off. Now slowly working on pulling the crankshaft out.
Thanks again. I will be sure to reply promptly from now on.
