Ok this is driving me nuts!
Hi,
I've been trying to remove the interior plastic trim on the c-pillar for several days now, but I can't get it off
Well after removing the velvet-like trim on the rear door frame I found a metal clip, unclipped it and I'm stuck now, I tried moving the plastic trim in every direction but it won't budge! I'm sure its not the seatbelt thats keeping it stuck.
This is what I'm talking about in case I don't make much sense (I usually dont) http://mb.braingears.com/124_DISC2/P...sis/68-449.pdf
Regards.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Regards.
Did you remove the speaker housing? I has to come off also before the side panels canbe removed.
mmmmm, no..........
Actually I was trying to do that today, the speaker cover has to be removed from the boot right? Do I need a special tool to remove the trim from the clips, or can I just pull it by hand?
Thank you.
Thank you.
