spring pad discussion (no gay secks talk allowed)
So, at least for spring pads on the front suspension, you can pretty much assume that a 5mm change in spring pad will amount to approximately (due to possible error inherent to measuring a drawing) a 10mm of change in ride height.
If someone can measure these points on actual suspension parts, we'll get a more accurate number, if anyone cares that much about it.
This thread rules - it's making everyone geek out!
I made a quick drawing to help illustrate this. But I disagree with you. The principle is the same- there is a multiplicative relationship between pad height and ride height. That's the principle, and it's the same regardless of whether the spring pad is on the top or bottom. Sure, if you took the old spring pad off the top and installed the new one on the bottom, it wouldn't drop the car as much as expected because it was installed wrong. But the mathematical principle is the same, assuming the pad is installed properly. jeeze. That will teach me to try and help.
let's look at the spring pad sizes
8 +0 = 1 bump
8 + 5 = 13mm = 2 bump (5mm)
8 + 5 + 5 = 18mm = 3 bump (10mm)
8 + 5 + 5 + 5 = 23mm = 4 bump (15mm)
If you keep adding more thickness it will raise more than 5mm to start because of the angle of the lower control arm. It does matter where the spring is centered in the suspension because that would affect the ratio it raises or lowers the suspension from the pivot point.
So i don't see where we have a problem because the answer is YES your right..
