Tranny Service
) and I cannot, for the life of me, get any autoshop to do my tranny flush/fluid/filter!!?! Does anyone have a link to any tranny service DIY???
-Matt, does the DVD have anything tranny related (Service wise)
PS: I wanna thank you guys in advance, I also wanna point out that Matt has always been very helpful both pre and post surgery
.thanks!
http://www.mercedesshop.com/Wikka/Trans7226Fluid
there is a link to a DIY on mercedesshop.com
apparently even though it says that it's from a '97 C230 there is a guy in a thread who links to it, that says that is the same tranny...
No shop will do it, I kid you not!
Every time I mention the mileage shops freak out
and everytime I turn around and give the same responce - "...I knew it."
lol j/khope that link helps man, and good luck
.thanks!
I'll check the CD for you.
Remove the drain bolt, its an allen, let it drain. Then turn the engine over with a 27mm socket at the crank until the Tconverter shows its allen drain plug, remove and then reinstall. Torque specs are low and just enough for it to be tight, dont pull much more when the bolt stops.
Then remove the tranny pan, 6 bolts (10mm), remove the filter, flat thing right there, that another 3 bolts(8mm), put the new one in. Change the gasket and bolt the pan back up. Figure out how much fluid your tranny takes, pour in half and start the car with the parking brake on. Let it warm up and then shift into drive for 5 seconds, Reverse for 5 seconds, then to park, check fluid. Repeat this until fluid level is good and tranny actually engages, it wont with low fluid at the start but dont pour in all of it either as you could damage seals before the Tconverter gets full.
Good luck and check it for leaks once you get done with it and drive it 10 minutes once the fluid seems right and recheck while the engine is running and warm.
good luck
Pete
good luck
Pete
Pete that sounds simple enough, thank you kindly sir.
The w220 in the pic is SO freakin' comfortable...I love those seats!
but I think the w221 and the w140 are superior cars because of the build quality...but that's just me.
Never even thought of that
LOL
