What is the Wiring Harness???????
2006 E500 AMG PKG/2010 Camaro SS/RS - 2007 F-150 - 2007 Suburban
1992 400E
I am told there is only an "upper" harness - no lower harnes on this vehicle.
Is this true??
Does the "upper" wiring harness include the sparkplug wires as well?
I appreciate the info.....
Steve
Is this true??
Steve
Yes, there is a "lower" harness, but some people may not be familiar with that terminology. It's probably better known as the starter/alternator harness. It goes from the CAN box area to the starter, alternator, oil pressure sensor, and I think a couple other things. Mine was toated when I replaced it--definetly good to replace if you've done the upper harness.
The upper harness does not include the actual spark plug wires. It just connects to each of the injectors, temp sensor, and some other miscelaneous thingies.
