Flex disc ?'s
Old Nov 20, 2006 | 12:32 PM
bjay51d's Avatar
1989300CE(sold),1996Accord,02CBR954
Flex disc ?'s
Im heading to Ray Catenas to pick up a flex disc....I dont have a manual for the car yet is it a simple job?.Do I just pop out those 5 or so bolts?Also Anyone know the torque values of these bolts? Any advice is appreciated.
Old Nov 20, 2006 | 01:00 PM
shadowgriffen's Avatar
is a German Tank
There is a link to the instructions somewhere around here...I think Matt was the one who linked it.
From what I've heard its not a novice taks for sure, but you dont have to be a rocket scientist either...I'll see if I can find you the link.
Old Nov 20, 2006 | 02:29 PM
bjay51d's Avatar
looks pretty straight forward.I ordered a rear flex disc from ebay for $56.Ray Catena wanted $117
Old Nov 20, 2006 | 02:35 PM
mgw_300e's Avatar
Dora the Explorer
The only instructions I can find are how to inspect them. From the diagrams it looks like unbolt/bolt/done. I don't have the torque specs.
Old Nov 20, 2006 | 02:42 PM
is a German Tank
I saw those! I'm thinking of tackling this next summer, please document procedure if you do.
thanks!
Old Nov 20, 2006 | 02:48 PM
bjay51d's Avatar
I think the front flexies are the ones that give trouble.Looks as though one might have to drop the cross brace to get decent room to work.
Old Nov 21, 2006 | 12:34 AM
mouramen's Avatar
1985 W124 200D
You have to have the strenght of an ox and prepare for some striped nuts/bolts!
Yesterday i toke the tranny of my w201 out for selling and it was a b!tch, the bolts of the flex discs were removed with a hamer and sizel, , and i only managed to remove the front flex disc with the tranny on the floor and had to grind one of the bolts!!!!!
Old Nov 21, 2006 | 01:50 AM
ptoro01's Avatar
86 W124
taken lots of these out, I would say to mark both sides of the drive shaft so when they separate you can put it back properly. All you need is a proper set of tools and a breaker bar. The driveshaft also splices into the middle hole of the flex disc.
GOOD LUCK, THIS ONE IS ALMOST FUN
Old Nov 21, 2006 | 09:17 AM
bjay51d's Avatar
Yikes! You had alot of trouble with the rear flex.I checked the front and it looked fine.
Old Nov 21, 2006 | 09:18 AM
bjay51d's Avatar
good tip thanks...
Old Nov 23, 2006 | 03:01 PM
cap'n jasper's Avatar
W124
You don't normally need to drop or separate the driveshaft or cross brace.
Undo all 6 bolts pry the drive shaft back with a large screwdriver or prybar and the flex disk can be removed and replaced. Make sure you put the new one in the right way round.
