Smoking 230te
Old Dec 9, 2006 | 06:07 PM
t28mrs's Avatar
89' 230TE
Smoking 230te
My 89' 230 te auto has just started using coolant and is smoking white smoke through the exhaust a little at idle and quite a bit more when the engine is under load during acceleration. The oil was recently changed (1 month before the problem started) and is still clear and not milky and im getting almost full oil pressure at idle with it rising to 3 when i touch the accelerator pedal, also temerature gauge stays at normal and i dont seem to lose any performance either so im puzzled as to what the problem is? Any ideas. Thanx
Old Dec 9, 2006 | 08:23 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
white smoke + loss of coolant = Head gasket. Go to a shop and have a leak down test performed on you cooling system and on each cylinder.
Old Dec 10, 2006 | 06:20 AM
t28mrs's Avatar
89' 230TE
sounds expensive! What sort of job to do the head gasket DIY? will I need any special tools? If not then it looks like xmas dinner will be onion soup without the onion :-)
