AMG Bumper Question
If I took off the impact strips could I install it over the rest of the oem bumper?
I really have no idea.
This is a benz, the bumper is one of the first impressions the vehicle makes, if you slap on some crummy paint-job-fiberglass bumper, you will ruin this car. It will be in the same visual league as a ricer honda with the guppy fish bumpers in the sense that they don't go that extra mile to prep the friggin bumper so it looks even cheaper. UGH. Prove my concerns wrong before you go any farther and waste money and ruin the car.
the front bumper comes off with minimal effort, as does the impact strip. Take this off and try a dry fit. If you think it will work i'd sell your front bumper to some folks here since I have seen some racked bumpers. You will probably want to cut the lower portion of the existing bumper off since it will be visible behind the new open grates/mesh at the bottom. Might as well use a bumper already damaged that will be used as structure only rather than waste a good bumper if yours is good. anyways, regardless of that option, there are some very heavy duty automotive adhesives that auto body shops use that can be stronger than welded thin guage steel. You could always take it to a body shop and they could bond this new front bumper on your existing bumper. That way they have the special caulk gun and bonding chemicals and cleaners on hand, and they can make sure that it stays level and straight until it cures.
DO NOT RUSH THIS!!!
Good luck
DO NOT RUSH THIS!!!
Good luck
I'm about to leave for school again (Atlanta to Richmond) so I wanted to get it installed before I left.
I'll try what you said though. I am almost positive it will fit without the front impact strip, so I will take that off once I finish painting and take it up to a body shop. Thank ya'll for your help. I'll let you know how it works out.
This mess is scheduled for Tuesday. Motor mounts, right rear window, and cruise control are scheduled for repair Monday. I'm leaving Sunday morning, so I need to get this done.
Basically I'm sort of going through the college student phase. This bumper was just too good of a deal to pass up (ebay), as were the Vogtlands that I just bought.
Thank you for your help.
Git 'er fixed properly and you'll have a sweet benz in progress!!
In terms of having the rest of the kit, it doesn't really bother me. I don't really notice side skirts in terms of AMG or any other type of aftermarket side skirt, but if I can get my hands on a rear lip then I will. But I'm not going to pay $600+ for it, which is all I've seen them go for.
I play baseball in college, and the spring is when our season is, so I don't have time to work on the car at school. So you see the mad scramble for me to get my car's life together. I've done a full exhaust, mounted this bumper, new engine mounts, new rear window regulator, air/oil filter change, and oil change in the last 4 days. Unfortunately I'm going to have the Vogtlands for a while before I will be able to get them installed.
It Def needs a respray, but It'll hold up till after your season, we hope.
I don't think you need an entire body kit to make that front bumper work, judging from the side shot it seems to be a few degrees slanted somehow, like its not hanging properly, sorta looks a tad like it's clinging and not attaching.
Drop + respray + Euros + front bumper adjustment = done.
.02
.02
