New engine?
Old Jan 6, 2007 | 11:37 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
New engine?
My engine (M104) has 156,000 miles on it and I only have records back to 138,000 miles. Is there any way to know if the engine has ever been replaced? It just seems to be too clean and leak-free for that many miles. The car was out of state until 2004. Are there numbers on the engine that should match the car's serial number?
Old Jan 7, 2007 | 12:50 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Probably. My car is about 100k miles, and so far (knock wood) its amazingly well running! I think you may just be experiencing a garage-queen plus the engineering marvel of benzo. Hopefully your car is just being friendly as has just aged properly, and did not have its engine replaced.
Old Jan 7, 2007 | 12:48 PM
faithful_lothario's Avatar
C280
Thats highly impossible. i have a carefully driven 1995 C280 with 103000 miles and its got a head gasket leak, and i think the radiator is about to go out. after 100K miles, there will definitly be leaks in an engine.
Old Jan 7, 2007 | 03:23 PM
mgw_300e's Avatar
Dora the Explorer
could also be that the head gasket was done after 138000 but before the OP bought it.
Old Jan 7, 2007 | 05:40 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
Next time you change your oil look for the engine number to be stamped on the block, I believe they are usually under the intake, or on the drivers side. That way you can call it in w/your VIN to the dealer.
