Please Help!!!
At last the end has come....
So, I ask you all...
(The car in question is a 1992 300E 6 cylinder 3.0 liter engine, W124 Chassis, Sedan, 150,000 miles)
What do you think happened?
What may need checking out?
Could it be the bearings?
And any other helpful info!
PS. What about the alignment, could it be that?)
1. They almost never go bad.
2. When they do, the noise is constant and varies in volume with wheel speed and turning.
It sounds more like some kind of suspension issue. Maybe worn bushings combined with poor alignment made worse with a sudden, hard stop. Check for play in all of the suspension bushings, ball joints, and tie rods.
You may have had a wear/tear issue about to happen that was worsened by the sudden stop.
Does the sound happen any time the wheel moves, meaning at all speeds?
Sounds to me like a tire issue.
But how would the tire alignment make that vibrating. The steering wheel isnt jerking back and forth or for that matter pulling extra to one side or the other.
If it does need changing could it wait a thousand miles or so. I plan on getting some AMG rims for my car, and I dont really want to shell out more money for tires that will eventually be sold...unless the new tires should be put on pronto.
...glad its just internal tire damage (no, you won't wear down a flat spot and even things out) and not a brake/suspension component thats damaged.....
