Audio!!!
One more thing, any of you all have a recommendation on a good speaker size. I plan on adding some subs in the trunk in the future, just to let you know
THANKS!
Jody
Just make sure once you're ready to remove the panel that you slide it straight up. Don't pull it towards you.
There aren't really any "clips". They are more like hooks. Unless you pull the panel towards you, you aren't going to break them.
As for speaker sizes and subs. My absolute best recommendation is for you to only replace your front speakers, disconnect the rear speakers completely and once you install a sub, remove the rear speakers so that the bass can vent through the holes.
A good front sound stage (which you will have with a nice set of 3-ways) is all you need. Most car stereo gurus don't like rear speakers at all because it's unatural to have music coming from behind you. This way, you won't have to make any modifications to your rear deck, and you'll get a reasonable amount of bass into the cabin.
I went for a much more in-depth installation than that, but this is what I recommend to most people because its cheaper, less work, and doesn't cause any permanent modifications to your interior.
You can fit a 4" in the dash and a 5.25" in the rear deck. To fit the rear deck speakers will require some minimal cutting. I wouldn't even bother with the door speakers, as you would need to use a 5.25" with a 2" or less mounting depth, these are not easy to find, then you would have to rewire them so you get something more than just low frequencies.
I run Infinity Kappa 4" in my dash, Infinity Kappa 5.25" in my rear deck. I have some Kenwood 5.25" co-ax in my doors and a small ADS amp (replaces the OE amp) running them. They get a low level signal from my Pioneer DEH-P80BT head and the deck powers the fronts/rear. For low's, I have a Basslink II, which does not require removing of the rear speakers for the bass to get into cabin.
Don't worry about exact sizing for the dash, a standard 4" will drop in, but will leave gaps, you should be able to get at least two screws in, which is enough. Keep in mind that you should not be using the dash speakers for low frequencies, so cross them over around 125 hz, same for the rears.
I might add a 10" or 2 in the trunk later though but i don't want to replace the deck, i don't like how the newer decks look specially in a 124,is it possible to use a stock 124 deck with an amp and a woofer just to smooth out the low end a bit?
I have one in mine and it looks factory, down to the orange backlit display.
if your speakers are already running off the head unit, replacing them should be a matter of just unplugging what's in there now and putting in aftermarket speakers.
i broke two or three of the hooks for the door panel because i knew there were hooks, but did't know where, and i tried to pull 'upwards' and... anyway. the panel still fits pretty snugly though.
this link might help you:
http://www.mercedesshop.com/Wikka/W124DoorPanel
BTW: is the box on the left side of the trunk the amp that you guys speak of? Also, anyone know who makes the OEM speakers? I was all set to buy a bunch of MB Quarts and then I heard the stock speakers with the new Kenwood head unit and decided I could go a long time before another set of drivers would sound significantly better. I'll probably just add a sub to finish off the sound balance and take some pressure off those mids in the doors.
Time alignment in a W124 would be best achieved by placing your point source drivers on-axis and as far away from the listerners ears as feasible (kick panels). But in reality, these types of audio configurations are not optimum for daily driving, so we make due.
The newer heads on the market today allow for more precise time alignment, case in point, my DEH-P980bt, which includes a microphone to automatically adjust the output volumes for optimum listening experience (driver), they even manipulate the rear speakers so as to mute and/or diminish the output.
