Oil?
Old Mar 1, 2007 | 05:34 PM
JDW124's Avatar
Oil?
Foo's at Autozone say 10w40 for the 300e. What do you guys say? 40 alright or go thicker or lighter? It's not for an oil change, just leaking... -_-..
AND BTW!!!! My friend's 300e has this splash guard type thing underneath the engine and it catches all the crap the engine or tranny leaks. Mine doesn't have one! Are they meant to come with the car? Easy to put one in?
Old Mar 1, 2007 | 05:39 PM
oneill_1's Avatar
MB 300E | BMW M Coupe
i use synthetic oil.....Mobil 1 (0W40), i dont know if it's the best but my mechanic said that it is fine for my car...
-OG
Old Mar 1, 2007 | 05:40 PM
JDW124's Avatar
Oh another question. I was messing with my idling a few minutes ago. What direction does it go? Is counter clockwise reduced RPM's? And I have to push it down and rotate right?
Edit: btw thanks for the reply. Guess I'll stick with the 40 then
Old Mar 1, 2007 | 06:07 PM
CDP's Avatar
CDP
W124's
The previous owner always used Mobil 1 synthetic on my car so that's what I use as of right now.
When I had the 300E - I used Mobil 1 10W-40.
Omar, I highly suggest you stop using synthetic until you fix your head gasket.
Old Mar 1, 2007 | 06:11 PM
PaulX608's Avatar
2011 VW cc, 2004 ML350
My '93 400E has always had 10W40 in the winter and 15W40 in the summer. That's what was in all of the service records and that's what I've used since I've had it. Doesn't lose a drop between 7500 mile changes.
Old Mar 1, 2007 | 06:29 PM
oneill_1's Avatar
why?
-OG
Old Mar 1, 2007 | 06:46 PM
mgw_300e's Avatar
Dora the Explorer
Originally Posted by oneill_1
why?
-OG
synthetic can leak more, and it's more expensive
Old Mar 1, 2007 | 07:25 PM
JDW124's Avatar
My car leaks drops quite a lot as well. Any oil recommendation for that?
Old Mar 1, 2007 | 08:20 PM
DarkHand's Avatar
1994 White an Grey E320 "Shado"
AND BTW!!!! My friend's 300e has this splash guard type thing underneath the engine and it catches all the crap the engine or tranny leaks. Mine doesn't have one! Are they meant to come with the car? Easy to put one in? [/QUOTE]
As for the panel underneath the engine compartment. Yes your car should have one. They sell them online. There should also be one for your fuel pump fuel filter area too.
