somewhat of a wheel question (sorry)
so I guess now my questions is: does anyone know if 44 offset sits too close for a 124? And If it does, I just add spacers right? so then I have to worry about if adding a 5 or 10mm spacer pushes the wheels out too far?
I would be extremely surprised if you could get ET44 to work. it might hit your struts/shocks when you hit a bump.
IMO, I wouldn't go wider than 8" in the front for handling reasons. Hell, if I could do it over again, I would get 7" wide in the front and 8" wide in the rear. I would put spacers on the front to get the wheel closer to flush with the outer fender. The problem with wide wheels in the front is that ruts in the road have more leverage against your steering components and can cause your car to steer all over the place unexpectedly. I have to pay attention when I'm on crappy pavement.
i had too many problems with spacers, getting longer wheel bolts, spacers not fitting properly, etc., so i just ended up getting new wheels.
what style are you looking for? maybe we can help you find some that would work for you.
