Ecu ?
The bosch part #0 280 800 304 /mercedes#008 545 16 32 These are the two part numbers on my ecu.which is off a 1989 300cE
there seems to be a **** load of different ecu numbers for these cars.I found a couple of bosch#006 545 64 32 which is for a 1989 300E.Does Anyone know if its possible to swap these ecu?
I believe your car still had the old style fuel pump relay and not the MAS relay. I remember the MAS starting in 1990. I could be wrong.
I had several old style relays with a failing solder joint for the main pump relay contact. It appeared the heating and contracting caused the joint to crack around the pin that was soldered. When cold the contact was sufficient. When the joint heated after driving, the car would die and the joint would need to cool before restarting. This failure was easily visible and cured by reheating and resoldering the connection. I fixed many cars this way and it's easy to pop the outside cover from the relay. Just reseal after inspection with your regular goo. I fixed more relays this way than I saw fail for other reasons.
Good luck and keep us posted.
