Is there a w124 DIY/FAQ thread floating around?
Old Mar 23, 2007 | 08:41 AM
dragonfli_VF's Avatar
01 VF3 VR6 Jetta / 89 300E "Helga"
Just wondering and would think that it would be a source of very valuable information for the readers of this forum section...
anyone have any leads or links?
if anything, an engine rebuild DIY would be most helpful...
part numbers for items needing replacement and what not... I am NOT going to take it to some stealership so they can molest my already thin wallet.
Old Mar 23, 2007 | 11:08 AM
MediumKahuna's Avatar
92 300TE 4Matic
I found a lot of good DIY stuff on mercedesshop
I come to MBWorld 'cause these guys know best how a 124 should look and you can buy/sell stuff right in the 124 forum. Other forums (there's only about 500 of them) have more DIY stuff.
Of course, I may change my opinion if somebody on here tells me how to remove and reinstall my drivers side kick panel.
Old Mar 23, 2007 | 01:48 PM
cap'n jasper's Avatar
W124
I presume the kick panel is the back of the seat.
First remove the two screws at the bottom of the panel.
Then compress the seat bolster to ease the load on the leather side piece. This will make prying it off the seat back easier. The side piece needs to be eased backwards and off the seat back. Hopefully these pictures will make it easier to understand how it's held together.
Attached Thumbnails Is there a w124 DIY/FAQ thread floating around?-seat.jpg   Is there a w124 DIY/FAQ thread floating around?-seat2.jpg
Old Mar 24, 2007 | 10:48 PM
92 300TE 4Matic
Originally Posted by cap'n jasper
I presume the kick panel is the back of the seat...
No its on the left of the drivers foot well, plastic about 1 foot by 1 foot (30cm)
I found this pict of the panel I need to remove:
The reason I want to get it off is to get at terminal block X30 behind it:
Thats the brake peddle at lower right
Old Mar 26, 2007 | 12:01 PM
I needed to know this one! thanks for the unintentional mistake!!
