oil light on when turning left
Oil pressure is 1-3 bar during operation and level is at max on dipstick. Dash oil level light comes on momentarily only when turning left and goes off when wheel is straightened. No light at all when turning right or during idle or acceleration. I'm curious. 1987 300TDT with 213K.
aldo b.
aldo b.
1995 E320 SE, 162,000 Miles (Sold)
Sounds like an instrument cluster relay problem. Here's an excerpt from the service manual. There must be a 60 second time delay.
According to my post above, which is directly from the service manual, the sensor is supposed to show low oil level when turning left. The circuitry in the instrument panel, a, is supposed to suppress the fault for 60 seconds. So unless he is making a left turn that lasts 60 seconds, there should be no light. The problem is in the circuitry, not the sensor.
1 Post
2003 E320 4Matic Wagon & 1997 E320
1) bad sensor. Easy to check. Pull off electric connector and measure the resistance of the sensor. Should be very small (0.1 Ohm).
2) The electric plug resistance is too high. Spray some contact cleaner on it. You can also check using an Ohm meter but that require the measument of a pin on the instrument cluster.
3) If the above are OK, then the cause could be the cluster and the 60 s circuit.
3) is expensive and also less frequent. 1) and 2) are pretty cheap and more frequent.
Mine was a leaky injector diluting the oil. Changed the oil and it stopped doing it for a while. I eventually fixed the injector and have not had the problem.
Smell the dipstick just to be safe.
