Need help with radio swap for W124
i think i figured out the spreaker wires.
for the rest, i think the red wire is the power, brown is ground, and black is the amp turn-on??? I think the red with the yellow stripe is the ACC. I also have TWO blue ones with white stripes, and one black with a whitish greyish stripe. ideas??
If you're not sure which wire is the remote turn-on wire, use your voltmeter again. With the battery connected, put your key in the ignition and turn your key to the "ACC" or accessory position. Touch the red terminal on the voltmeter to the wire in question. If you get a reading on the voltmeter, keep it connected while you turn your key off. If the voltage drops to zero in correlation with turning off the key, you have your remote-turn on lead.
I have to disclaim this though. I'm not a professional, so use your best judgment. www.mercedesshop.com has some great forums. If you haven't tried them out, spend a couple hours clicking around over there and you might find what you're looking for. Let me know if this doesn't make sense.
Good luck.
i found this in the mean time:
http://www.beckerelectronics.com/1492.html
so the installation continues tomorrow! even though i also just realized i might have ordered the wrong size of speakers for my front doors... they get here next week, i guess i'll know for sure soon!
On my TE I had it installed professionally and they used an adapter...are you saying its possible to avoid spending the $30 on the adapter? Is the plug that goes into the back of the OEM Becker unit the same size+shape as the one that goes into aftermarket HU's?
I'd like to get all info before I pull her out as I plan to get all my wires down for the amp too. Any tips on getting the wires into the trunk on the sedan? My wagon was easy obviously...
Can you explain to me why the fader won't work with the aftermarket HU? Why can't I use the fader? My TE still has the fader functional. I understand the built-in fader on the HU won't work with the fader on the console and vice versa. I'd rather not run new cable to the rear speakers if possible.
Any recommendations on a cheap amp wiring kit? I used the complete 8 gauge KnuKonceptz set before in my wagon and it worked out well...but they increased their prices by quite a bit since I last bought from them. I paid $16 for the whole kit in 2007 and right now the same kit is $25.
I plan to build a small enclosed box and have one single 10/12" sub on like a 300W amp. Nothing crazy at all. Just cheap n cheerful like the wagon has.
Some cheesy audio dealers will just use two channels of your head unit and run it through the OE fader. You run the risk of burning up the fader (not rated for high power) and you lose 50% of your new decks output power.
Its actually easier to just run new speaker wire, but if you just dont want to do it, what you will need to do is pull your console and get access to the speaker wires that come off the fader (output side), should be four sets, you can cut them anywhere after the fader and splice in some new speaker wire and run it up to the dash area where the deck is. I don't recommend this method though as the OE wire is 18awg and you should really be using a minimum of 16awg.
This diagram should help you understand how the OE system is designed.
I'll let you guys know how it goes.
....I will bypass the fader then!Silly me...
Gonna try and get it working today. I'll take some pics for a DIY article maybe.
EDIT: I think I just found the W124 stock wiring diagram.
YNV does this look right to you?
http://www.the12volt.com/installbay/...tail/1416.html
Is there any way to test to see if a speaker is blown? My right speaker doesn't work at all...I might just replace them all anyway, but for right now if I could get it up and running that would be great.
As for the amp, the 94/95 is also almost identical to the 92+ W124, where as the head unit powers all four speakers (front dash and rear deck) and there is a small amplifier in the rear trunk that powers the sub's in the door. Now if you want to retain the OE amp, it takes high level inputs from the headunit and these inputs are tapped off of the OE dash wires, so if you rewire your speakers, you need to located the inputs for the amp and wire those up also. If I remember, there is some sort of Y connection back in the dash somewhere where this occurs. Most after market installs don't address this, so the door speakers don't end up working.
The 400e/500e had two amps back in this location vs. the single amp of the other models. There are two descriptions for the different sound systems, the "Active Loudspeaker System" and the one in the 400e/500e which is just referred to as "Sound System".
The pre 94 models are the ***** because of the manual fader AND the fact that the Becker is a two piece unit, with the tuner in the trunk, so you know what that means....no antenna plug in the dash, so if you want a radio when you install a new head unit, you get to also run a new antenna wire!
I have a Grey/Blue, Red/White, Brown, Black/Yellow
Obviously the brown is still ground...but what about the others?
The new headunit has its own ground...do I leave the brown unconnected then?
I made a mistake years ago when i posted that because I forgot i used gray for the ignition wire. You don't use the gray/purple.
This says red/white is constant +12v
When it comes to the front speakers -- There is a green+black for right speaker, and red+black for left speaker. I assume black = ground, right?
I'm just double checking everything here as this is the first time I've done this...I feel totally confident as long as I got the right connections laid out for me.
I also ran longer wires to make sure in the future any new HU will be easier to connect. BTW, I have fuses on all the power cables just in case.
There's no possible way you can mess up. If you short something out you'll just blow a fuse. If you connect the wrong power wires, the stereo will turn on but not keep the memory so just swap the wires and that's it.
Look at this...what is this plug? It was connected into the back of the becker unit...I can't figure out what it goes to. Maybe this plug is something to do with why its not turning on? Could this be the power antenna/Auto-Antenna Relay? Its the only wire remaining that I have not attached yet to the HU wire connector. That still wouldn't explain why it isnt turning on though would it?
Also not sure what the blue/white goes to as I don't have a blue cable attached the HU wire.
ok, just checked again and that wire with the circle should be the power antenna cable.....everything else is how i described...
So let me clarify -- Do the front speakers go straight to the headunit for the stock becker system, or does it go through the fader first?
I switched the constant and ignition power wires and I'm still not getting any power...
Any ideas? The stock headunit was powering on today...
Like 2phast said...
