Ezl
With your problem this may be a possible cause. Unfortunately your problem is not something common to these cars so you will either have to be proficient with testing when it fails or resort to parts replacement. The ignition system is pretty basic. Crank sensor, EZL, coil and the secondary ignition system(cap & rotor,wires,ends,plugs,etc.) If it fails every time at temp, then a shop should have no problem diagnosing the problem.
The EHA ( Electro Hydraulic pressure Actuator ) is located under the fuel distributor.
It takes a signal from the KE Control Unit and regulates the amount of fuel based on speed/throttle/temperature, etc that flows to the injectors.
Not meaning to be sarcastic, but "if you have to ask what it is, then you shouldn't try to adjust it"
Get it out of adjustment and you'll have many problems, from starting to idling, to accelerating and possible fuel leaking !!
What symptoms are you exhibiting ???
