Some Oil on a spark plug !!!!!!!
Old Jun 16, 2007 | 11:16 AM
black320's Avatar
94, E320
Hi guys,
I was chaging my car's spark plugs and found one of them is covered with oil... what does that mean?? does the engine need to be rebuilt or what??
PLZ help
Old Jun 16, 2007 | 01:16 PM
n8nod9it's Avatar
bmw
Where is the oil? On the electrode or on the outer surface where the plug wires go on? If its on the outside, then you should look at the valve cover gasket, which is likely leaking and can cause rough running as it drips down into the plug.
Old Jun 16, 2007 | 01:46 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Yes, I had this happen too, on the number 1 plug. Oil on the outside comes from the valve cover gasket and is no big deal, unless it's a large amount. Mercedes recommends cleaning the oil out of the hole before removing the plugs.
Old Jun 17, 2007 | 05:25 AM
black320's Avatar
94, E320
No guys,
It is On the electrode (inner part) and it is on number 3 plug only ... is it a big deal or not ???
Old Jun 17, 2007 | 01:45 PM
shdoug's Avatar
Originally Posted by black320
No guys,
I'm not sure what would cause that and it is strange. Does the engine smoke or run rough? Number 3 plug fouling? If there are no other symptoms I wouldn't worry about it. If there was a large amount of oil coming into that one cylinder when it's running, then there would be something serious wrong, like a broken piston ring or maybe valve guide seals. These engines are practically bullet proof so it's probably OK.
Old Jun 18, 2007 | 04:51 PM
autosleek's Avatar
Hi guys,
PLZ help
my guess is a worn valve guide seal.
Old Jun 19, 2007 | 02:20 PM
Lorinser880's Avatar
'87 260E
No guys,
It's oil fouling-2 causes, valve guide being the most common, not expensive to replace. The other is worn bores/piston rings.
