Steering gear box play
normally excesive play in the steering is a result of wear and tear of the components part of the whole steering assembly, not only the power steering gearbox. As far as I know there is not adjustment possible, other than replacíng the worn out parts, also outside the gearbox.
as far as i know...you can make a small adjustments on the steering box...but this is only a tempoarily because in the near future...the problem comes back.......but the best solution is to replace the steering box...this may require a bit of work....but it is worth it in the end.
