Seat Belt Warning Light Intermittent
Old Oct 15, 2002 | 08:53 AM
Carl NH's Avatar
1987 300D Euro
In my 1987 300D the seat belt warning light comes on while driving (when I am belted in). I have replaced the overhead courtesy light console this is housed in, and checked the wiring in the area.
Also this occurs more when wet/damp outside. I suspect a short in the wiring circuit, but wanted to hear if others have had this problem and what a possible solution may be (before I remove the bulbs permanently).
Carl
Old Oct 15, 2002 | 09:19 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Unhappy
I experienced the same thing for some years, every once or while. Checked everything, could not even reproduce the appearance when I wanted it. May be the whether conditions are the problem. I have my cell phone under strong suspicion. No fix that I know of.
Old Oct 15, 2002 | 09:23 AM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
i belive there is a relat that controls dome lamp and door chime operation ,if this relay is bad can cause an intermittent seat belt lamp filcker.
i could be wrong
Old Oct 15, 2002 | 09:28 AM
Carl NH's Avatar
1987 300D Euro
DSMIT,
If this is the same relay, would this not also sound the warning chime as well?
Basically it flickers on/off w/o the door chime.
Old Oct 19, 2002 | 10:44 PM
Rafael Grullón's Avatar
E420 Sport
Lightbulb
Does the courtesy light comes on with the warning light, even for a moment?
Does the warning light work properly otherwise? That is, does it blink for about 15~20 sec when you open the door, and then turns off?
Did you check your door switch for rust/false contact?
Rafael
