Wagon Chat - Advice/Pics/Kick the Can/Whatever...
Rating: Thread Rating: 5 votes, 5.00 average.
Old 11-09-2011, 09:35 PM
  #601
POS
POS's Avatar
1966 250SE Cab, 1985 500SE Euro, 1985 190e 2.3-16 AMG, 1986 300E LeMons Car
Originally Posted by Chappy
I probably would if I had an aero kit. I debadged mine and painted the rear star black. Other than that, I've left it alone.
I've got a black/black wagon too and debated painting the lowers black. I love the look, but I want durability more I guess.
Old 01-14-2012, 10:44 AM
  #602
Chappy's Avatar
AMG
Mine is being more as a daily workhorse. I'm putting 800+ miles/week on the kombi now so my resources are targeted towards maintenance and repair necessities. I still get a 22 mpg average in mixed driving so not too many complaints!
Old 05-07-2012, 02:21 PM
  #603
octavius's Avatar
300TE
I was wondering if anybody could tell me where to locate the taillights that have clear sections for the turns and reverse? My tails are all cracked and some broken tabs on the inside.
Old 05-10-2012, 09:42 PM
  #604
octavius's Avatar
300TE
Just installed my new H&Rs yesterday and I'm not sure they are my thing. First issue is that i only bought new springs after replacing my blown OEM shocks with KYBs. While under there I found that one of my stock front springs was broken at the bottom. So I pop on the new H&Rs and #1 pads and now I am literally riding on the bump stops. Next step is to go back to my stock #4 spring pad and trim my bump stop by a single cushion ( any more and I will start rubbing) ... Any experiance out there that may help? Only wish I had the foresight to go with shorter bodied shocks... If all else fails I may have some H&Rs up for sale so I can go with sportline springs....
Old 05-13-2012, 08:13 AM
  #605
octavius's Avatar
300TE
Ok, slapped on the #4 pads and trimmed two cushions off the bump stops. The struts and stops are no longer touching and I have a decent amount of travel. Only rubbed under hard braking while pitching it into a corner hard. So far I am much happier.
I have not installed the rear springs yet as I am towing an 5x8 enclosed 700mi this week. I did turn down my sls a little in the rear to put a little more weight on the springs for the tow. Also picking up a set of 17" AMGs next week!
Attached Thumbnails Wagon Chat - Advice/Pics/Kick the Can/Whatever...-imag0249.jpg
Old 05-16-2012, 08:32 PM
  #606
Chappy's Avatar
AMG
Try ebay
Old 07-22-2012, 10:15 PM
  #607
Chappy's Avatar
AMG
Just hit 165,000 miles....still humming :-)
Old 01-13-2013, 04:37 PM
  #608
Chappy's Avatar
AMG
Other than routine maintenance, the only repairs in the past six months have been:
Replace ignition cylinder lock
Replace fuel pumps
....not too bad for an 18-y.o car with 177K miles.
Oh, I can highly endorse the Michelin Pilot SuperSport tires!
Old 04-08-2013, 12:49 AM
  #609
4.5_sport's Avatar
1979 VW Rabbit, 1994 E320T
So I bit the bullet and picked up an M119 (4.2) and trans to begin the swap on my 1994 E320T...
Pics and build thread to come...
Old 04-09-2013, 08:01 PM
  #610
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Cool! would love to know how much trouble you run into. I wouldn't mind doing the same thing to mine.
Old 04-10-2013, 12:44 AM
  #611
2doped's Avatar
1988 Mercedes 300ce
Can't wait to see pics and a build thread! Good luck!
Old 04-18-2013, 08:36 PM
  #612
4.5_sport's Avatar
Build thread soon... I just got the 6-cyl pulled...
Old 05-01-2013, 03:35 PM
  #613
michaelscoots's Avatar
'95 e320 Wagon, '92 300TE
Does anyone know what these wheels are called? I'd like to find a set for my black on black e320 wagon.
http://upload.wikimedia.org/wikipedi...W124_Wagon.jpg
thanks,
Michael
Old 05-01-2013, 03:36 PM
  #614
Oh, also, are these kits any good? If so, would they fit onto a wagon?
http://www.ilovebodykits.com/product...ody_Kits_.html
Old 05-02-2013, 02:39 PM
  #615
ZedStyle's Avatar
Youngtimer
thanks,
Michael
those look to be off a W203 coupe
Old 05-02-2013, 03:46 PM
  #616
Thanks, I think I found them...now I have to figure out if spacers are needed and what the new tire size will be...
Old 05-02-2013, 11:42 PM
  #617
ZedStyle's Avatar
Youngtimer
i think you'll be fine without spacers, and for tires i would consider 205/50/17 in front and 225/45/17 in the rear (these rims are staggered). The stock tire size for the c class will also work but they will be a little wider (225 in front and 245 in rear) and may increase the chance of rubbing. plus they will be a little more expensive too...
definitely check off these sizes with the tire shop to make sure they will actually work for you, these are sizes that will keep your new wheels close to the same diameter as stock wheels.
Old 05-05-2013, 08:56 PM
  #618
Wow, thanks! Just so I'm clear, the rear rims are wider? So, if I buy them I need to specify two front and two rear?
thanks,
Michael
Old 05-08-2013, 06:56 PM
  #619
300e5spd's Avatar
300e 5spd
headlight lens for 94 wagon
Hello,
I need a left headlight lens (USA drivers side) for my 1994 E320 wagon. Will a Euro lens fit on my USA headlight assembly? My cracked lens has part number 1 305 621 619 (Bosch). I found a Euro lens 1 305 621 804 but I have not found a USA lens but only a complete headlight assembly. Thanks for your advice!
Tom
Old 05-08-2013, 11:26 PM
  #620
ZedStyle's Avatar
Youngtimer
thanks,
Michael
yeah, those came on the Sport models I believe and are staggered (rears wider than fronts)
Old 05-22-2013, 09:24 PM
  #621
Chappy's Avatar
AMG
Awesome project - good luck!
Old 05-22-2013, 09:44 PM
  #622
Chappy's Avatar
AMG
Kombis rule!!
Attached Thumbnails Wagon Chat - Advice/Pics/Kick the Can/Whatever...-img_20110912_114808.jpg
Old 05-22-2013, 09:46 PM
  #623
Chappy's Avatar
AMG
Kombi in the middle....real or photoshop??
Attached Thumbnails Wagon Chat - Advice/Pics/Kick the Can/Whatever...-2012-03-03_08-37-46_698.jpg
Old 10-12-2013, 05:28 PM
  #624
Chappy's Avatar
AMG
Badge engineering???
KOMBI-fied!!
Attached Thumbnails Wagon Chat - Advice/Pics/Kick the Can/Whatever...-20131012_170705.jpg
Old 04-30-2015, 07:00 AM
  #625
zk124's Avatar
w124, w203 , w204
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: Wagon Chat - Advice/Pics/Kick the Can/Whatever...
