Warning lights and no start 300E
The car has 115K miles on it and appears well taken care of. The previous owner related the following: She was driving home from work about a year ago and the car started running rough and died at a stop light. She got it to restart and drove it home (aprox. 5 mi). Thereafter it would not start. An indy shop (not familiar with MBs) replaced the idle air valve with no cure of starting problem, she had the car towed home where it has sat until I bought it.
I put fresh plugs and a fuel filter in it and it started up and ran very well to my house (aprox 15mi) EXCEPT that after the initial startup and before leaving her driveway it died after about 5 min of running but restarted immediately.
When I got it to my house I started playing with it starting, killing, restarting etc. to see if I could recreate the no start problem. Sometimes it would start fine and other times it would crank but not start. I then noticed that the times it started that all the dash warning lights would light up across the board and all go out when it started. During the no start condition the only lights that lit were the SRS and CE and sometimes only the SRS. Also during the no start conditions I can hear the fuel pumps priming when the key was turned on and sometimes the car would catch for a second (I suspect from the residual pressure in the lines) but not run.
I would suspect the normal gremlins of OVP, FPR, ECU if it were not for the actions of the warning lights. Could the ignition switch be at fault ?
Any help or ideas would be greatly appreciated.
It could also be as simple as a loose wire connector somewhere. If I think about it later I will look at some wiring diagrams and see where the power from the igniton switch goes.
