Winshield wiper fluid warning light won't turn off
Old Oct 16, 2002 | 04:59 AM
spinnell71's Avatar
300 CE
I filled the holding tank with washer fluid. Also, the winshield washers aren't functioning. Any suggestions???
Old Oct 16, 2002 | 06:56 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Hi,
first check whether the washer pump is running. (you can hear the noise when the hood is open). If it's running and no water is coming through the valves, they either clogged or the water comes out somewhere since the hoses may have come loose.
If the pump does not operate check the fuses.
The indication light comes on when the fliud level is low. The sensor in the fliud tank may be not functioning. Take it out and check whehter the floater element is full of fliud and cannot float anymore. This means, even the tank is filled, the floater sences EMPTY, and causes the indicator light come on and may be shuts of the pump to prevent the pump run dry (but this I'm not sure whether this function is wired this way).
If the floater element is filled up with fliud, replace the part (I guess less than $20) it is no big deal.
Good luck
Old Oct 16, 2002 | 08:33 AM
spinnell71's Avatar
300 CE
Thanks for the suggestions. I lifted the hood and could not hear the pump. Where are the fuses? I just got this car a few months age.
Old Oct 16, 2002 | 10:05 PM
chupper's Avatar
The fuses are by the drivers side in this black case thing. It's like 4 inches wide and like 7 inches long (if I remember right?). You gotta unlock the clamp and open it up. The info should be in your manual. If you don't have the info about the fuses, E-Mail me and I'll post it on the forum.
The windshield washer system is quite intricate for 300E's. As you might or might not know, the headlight wipers come with the car, so there are 2 pumps coming from the container. Speaking of this problem I will post a new thread on the forum....
Old Oct 16, 2002 | 10:50 PM
spinnell71's Avatar
300 CE
thanks
I thought the black box eas an extra speaker (oops)
