Specialty lamp question
Old Aug 13, 2007 | 03:15 AM
White_Knuckles's Avatar
1994 E320 Dragon Wagon
1994 E320
Am I missing something with three aux lamps out? The headlight switch backlight, ashtray lamp and most annoying, shift position lamp are all out. I tried to remove the headlight switch lamp and it seems stuck into the plastic holder when removed from the switch assembly.
The shift select is a bit challenging as the console may need disassembled to find it. I wanted to get replacement bulbs first but then I thought with three out there may be a common power or ground fail. All fuses are fine. The other console and dash rockers lights work fine.
I'm thinking these all may be different and dealer only specialty lamps?
