300E Instrument Cluster/Odometer/Speedo Removal
Old Sep 5, 2007 | 09:43 PM
DrTofu's Avatar
1988 300E
I've got a 88 300E and the Odometer just stopped working.
I've managed to get the instrument cluster out of the car, and the speedo cluster out of the instrument cluster.
But I cannot for the life of me get the face off the speedo cluster.
There are two screws on either side of the speedo needle that I have taken out and the face becomes loose, but I cannot get the speedo needle off.(didn't want to force it and have it break)
I want to get it apart so that I can see what I need to fix the odometer.
Any suggestions?
Old Sep 5, 2007 | 11:46 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Any suggestions?
The needle will come off with some very gentle prying from behind it to loosen it up.
You might try using small plastic fork underneath the needle to apply even force as you're trying to lift up.
Old Sep 6, 2007 | 01:56 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
or do what my friend dose poke at it tell some thing happens.<_< >_> i dont know my odometer stoped 60,000 miles ago and was fixed i think for 50 bucks at a shop
Old Sep 6, 2007 | 07:03 PM
DrTofu's Avatar
1988 300E
Thanks, I'll give it a try later.
I would but they quoted me $195 + parts to fix it.....
Old Sep 9, 2007 | 01:35 PM
pifcat2's Avatar
300TE / 300E / 300CE
There's a company that sell the plastic gears if yours are stripped, I don't recall the site but you can Google it.
the method to remove the needle is to use two spoons on either side. The challenge is to replace it accurately or the calibration will be off (this is where the speedo shops earn their money)
Old Sep 9, 2007 | 06:15 PM
berti_00's Avatar
2016 Cls63s AMG
Any suggestions?
HEY buddy here is a little page that should help you out on it....
HOPE it helps
http://www.mercedesshop.com/Wikka/W124InstCluster
