New Projector Upgrade for Enzo, Zorro's Benzo!
Old Oct 8, 2007 | 02:05 PM
  #76
ZorroAMG's Avatar
Enzo, my Benzo
My lights look NOTHING like those in terms of beam pattern, those are terrible!!
I will post pics as soon as the retro is done.
  #77
Saijin_Naib's Avatar
1990 300ce 24v I6
Do you have a total cost of what this process will cost you?
Old Oct 8, 2007 | 05:02 PM
  #78
ZedStyle's Avatar
Youngtimer
at least there IS a cutoff, however disjointed it is... i have my lights focused down to the road but it's still bad. zorro, didn't you have some shields made for your HIDs in the OEM housings? if you do, you should definitely give them to me once you put in your new lights.
Old Oct 9, 2007 | 02:44 AM
  #79
gianfranc's Avatar
2000 Kleemann CLK 230K
Zorro, yah i didnt think you were getting a cutoff anywhere nearly as bad as mine, since you mentioned that your cutoff was almost what a true hid cutoff should be like.
I'm guessing that you are getting a cutoff like this ______/___/?
Are you doing a projector retrofit?
Old Oct 10, 2007 | 09:51 PM
  #80
ZorroAMG's Avatar
Enzo, my Benzo
Ok so I received the third version of the lights last week and here are the side by side comparisons.
I am going with the middle lights, the smoked version.
Below is a layout of the HID setup I will end up with once installed
(yellow HID fog bulbs and high beam HID bulbs are in shipping)
Since I am going with the middle lights, the end clear and blacks are for sale including matching corner lights.
Fantastic price of
$240 shipped!!! Buy em now!!
New matching sig!
Old Oct 11, 2007 | 01:44 AM
  #81
1990 300ce 24v I6
Sooo tempting dude! I would love the clears!
Also, can you detail a little what your doing with the HID bulbs?
Do you need new projectors for the H1/H7 and the H1 fog? Are there certain brands/whatnot you are using? Does this require custom work?
Old Oct 11, 2007 | 01:49 AM
  #82
ZorroAMG's Avatar
Enzo, my Benzo
Fogs point down and spread light on the ground, yellow is easy on eyes, no glare issues there.
Low beam projectors H& are decent compared to halogen setup now...may retrofit TSX or other 2.5" projector if I want PERFECT. Later though...no rush, these are good.
High beam is for highway and flashing, just need crazy output, do not care about glare cause you never have them on when oncoming traffic can see em. High, bright and far FTW.
Brands, nothing in particular, good quality though...plug and play-ish, no real custom work.
Hope that helps.
Buy the clears, ****.
Old Oct 11, 2007 | 05:04 AM
  #83
mbnz's Avatar
1990 300E
Originally Posted by ZorroAMG
I had the dude at the HID store hook up the projectors with the proper H7 HID bulb and it was GREAT...pics will follow, Daniel-San!
I live in Vancouver too. Which store did you go to? what brand/type and what was the cost? (parts and labour to install)?
thanks
and i love ur ride !!!
Old Oct 11, 2007 | 05:12 AM
  #84
1990 300ce 24v I6
The lights come with the stock halogen bulbs?
Old Oct 11, 2007 | 07:34 AM
  #85
Lorinser880's Avatar
'87 260E
Hope that helps.
Since you're using HID's also for your Hi beam, I suggest you get a set that fires-up right away, no warm-up delays. You won't be able to fully utilize the flash function due to the delay. Good luck.
Old Oct 11, 2007 | 09:09 AM
  #86
shadowgriffen's Avatar
is a German Tank
Hope that helps.
My car got backed into by my Genius Landlord last night, I WAS FOKIN PISSED!
so know I don't know Z...I was thinking of going Euros...but this sounds 10X more tempting now
I'll shoot you a pm soon
EDIT: He smashed my headlights + grill + scraped my front bumper...that little fgt.
Old Oct 11, 2007 | 12:38 PM
  #87
ZorroAMG's Avatar
Enzo, my Benzo
Stormy, you can do my black headlight set to keep your look going or you can go with my clear set....let me know.
mbnz, I went to revspot in richmond, bought a couple of kits from him, install was done originally on my first HID kit in Calgary then all i had to do was plug and play for the new kit.
Saijin, correct...the lights come with all necessary bulbs (halogen)..city, high, low and fog.
Lorinser, that is not an issue. Flashing will still be effective (much more than halogen even without a warm up) and high on the highway is for extended periods anyway....thanks for the concern though.
Old Oct 11, 2007 | 01:02 PM
  #88
is a German Tank
Z, are these plug and play (Keep in mind I have a six prong set up) ?
Old Oct 11, 2007 | 07:25 PM
  #89
ZorroAMG's Avatar
Enzo, my Benzo
Yep plizzzzzug and plizzzay bizzatch.
Old Oct 11, 2007 | 08:35 PM
  #90
Hakk403's Avatar
1994 E320
Mark, that looks HOT! I might have to copy you sometime in the future, that is sick man.
Old Oct 13, 2007 | 10:49 PM
  #91
Hakk403's Avatar
1994 E320
Still got sets for sale mark?
Old Oct 14, 2007 | 05:15 AM
  #92
ZorroAMG's Avatar
Enzo, my Benzo
Black ones and clear ones for sale...
Old Oct 14, 2007 | 05:04 PM
  #93
Hakk403's Avatar
1994 E320
LOL, I wanted to buy the black ones, but then I remembered the headlights are different on the 94's.
Old Oct 14, 2007 | 05:14 PM
  #94
1990 300ce 24v I6
These are the lights that are shaped for the facelift hoods, if you apply them pre-facelift, they have a gap.
Old Oct 14, 2007 | 05:15 PM
  #95
ZorroAMG's Avatar
Enzo, my Benzo
They are shaped for YOUR car Hakk....look closer at the pics...i am putting my eyelids on the new ones to compensate.
Buy em. NOW!!
Old Oct 14, 2007 | 10:14 PM
  #96
Federic0W124's Avatar
1992 400E
did you install yet mark?
stop being such a tease
Old Oct 15, 2007 | 12:25 PM
  #97
EvoW124's Avatar
W124
Originally Posted by gianfranc
Thanks. Haha. It's definitely bright but most of the useful light is on the right side which means that the full potential of hid is not being utilised.
This is the cutoff of tsx projectors. This is what I wanna achieve.
bro, once you had done your dad's!
tell me! mine also out la... same pattern like your pics! so most of time just don't on the projectors just the fogs only..
Old Oct 16, 2007 | 01:07 AM
  #98
gianfranc's Avatar
Sure i'll let you know how it turns out. Mbm is doing the retrofit now. And yah i also just turned on the fogs! Haha.
Old Nov 10, 2007 | 07:32 PM
  #99
oneill_1's Avatar
MB 300E | BMW M Coupe
^the pchops didnt do it justice....i like the turnout of the lights installed...been gone for awhile cause of my new toy...
-OG
Old Nov 11, 2007 | 05:31 AM
  #100
chewy4x4's Avatar
1992 300E
Zorro Why did you buy the lights for a post facelift?
