94 E320 lights on a 91 300E
Old Sep 20, 2007 | 08:39 PM
watut's Avatar
1995 E320 Cabriolet
Anyone try this before? My buddy just swapped his lights on his E320 and said hell give me his old stock ones for a good deal. Question is, do they fit on my 300E? I hate the stock lights, anyone upgrade to projectors and wanna sell their 1 pieces on the cheap?
Old Sep 21, 2007 | 07:37 AM
Jim's500E's Avatar
Yes, they will bolt right in no problem, except the lens is shaped to follow the contours of the 94' hood...looks a bit odd but yes, they are a direct bolt in job (sans the wipers if you have them; you'll need the wipers and motors from the 94' and the trim panel from a 94' with wipers...can't use the 91's)
You can easily find new knock-off euro-lites cheap enough as well, with the correct lens shape for a 91'.
Yep, HUGE improvement in lighting with the 94' and up W124 lights.
Old Sep 21, 2007 | 10:18 AM
shadowgriffen's Avatar
is a German Tank
You left out ONE VERY IMPORTANT THING!
You will need the euro prong 6 socket adapter for the headlights to work, without this, you're pretty much out of luck as you will not be able to plug and play.
Old Sep 21, 2007 | 10:28 AM
Jim's500E's Avatar
Smile
Yes, if he uses the euro-lites he will need the $2 adaptors. I did forget that major tid-bit ...my bad. He won't need to splice anything...just re-arrange the wires.
Not necessary with the USA lites from 94' into USA car 91' tho...plug and play.
Old Sep 25, 2007 | 11:57 AM
FCSmthree's Avatar
95 C36
If you don't decide to take them, tell him I would be interested.
Old Sep 25, 2007 | 05:52 PM
2PHAST's Avatar
500E Signal Rot
The 6 pin plug is not really a euro piece, its actually the same part number as the passenger side tail light plug, you would just need two of those
