last couple problems...
Old Sep 29, 2007 | 12:38 AM
s13guy's Avatar
1991 Nissan 240sx, 1986 MB 300e
first..front suspension..
has anyone had a problem with squeaking in the front suspension area? every little tad rock or bump in these crap houston streets, my squeaks..and its annoying as hell...looked at everthing i can, new bushings on the sway bar..and it still squeaks...
second..my sunroof dosent work..anyone have a diagram for a 300e sunroof? electrical, vacuum, mechanical...anything and everything..
Old Sep 29, 2007 | 03:33 AM
vili1982's Avatar
95 E320 Coupe, Diesel Golf
I had problems with my sunroom, try punching it while holding the button to open it, that worked for me. And check your fuses.
Old Sep 29, 2007 | 11:59 AM
s13guy's Avatar
the fuses are good...
i'll take a swing at it this afternoon and see if it works.
Old Sep 29, 2007 | 05:16 PM
MediumKahuna's Avatar
92 300TE 4Matic
Lot of things can cause squeeks. The worst to fix are ball joints and struts. If any little bump does it then see if just pushing on hood does it. if so then get a piece of hose and listen around for it.
The sun roof motor is behind the left (driver's side), rear seat back and works the roof by cables. Not sure if you can get at it from trunk (since I have a TE ). See if the motor gets juice when you push the button. Maybe can change the brushes in the motor if it does get juice but doesn't draw current. If draws current but doesn't turn (stalled) then something is jammed or rusted.
Old Sep 29, 2007 | 08:04 PM
s13guy's Avatar
well i fixed the squeaks..so thats done..
but the sunroof is another story..i found the switch on the roof panel was disconnected...but when i go to move the sunroof it gets stuck..opens on one side only..so how do i get in to where the sunroof actually is? do i need to take the headliner down?
Old Sep 30, 2007 | 03:01 PM
White_Knuckles's Avatar
1994 E320 Dragon Wagon
In the supplied MB tool kit there is a manual crank socket supplied. Nice, in case the roof hangs out on the road, in the rain. The socket is inserted right onto the drive motor shaft.
The sunroof drive motor operates cables that do the magic. Have you tried rotating the motor manually while someone helps the roof through possible binding tracks? The tracks can get dirty and cause binds. If excessive pressure is needed to rotate the motor or push-pull the roof you may have a bigger problem. A light grease applied to the tracks may free it once it's pulled to full open.
Old Sep 30, 2007 | 03:49 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Miscellaneous notes: The motor is in the left side of the trunk by the antenna. It uses a gear-driven positioner that must be timed correctly. If you turn the knob and don't get it beck in the right place, it will be out of sequence, but can be easily corrected. To get it back in time, I operated the controls until it was closed completely, then turned the knob until a heard a soft "click".
Good luck.
