Lamp indicator warning light
Are you quite sure all the bulbs are working? The indicator will light
if one of the rear license plate bulbs are bad. If not, behind the fuse box
are relays that control the bulb out warning. Remove the relays and
spray both the male prongs and the slots they fit into with electrical
contact cleaner.
hope this helps,
a'
or maybe you have a short somewhere...?
I had a loose tailight and my indicator was coming off and on randomly, turns out one of my tailights was loose and once I "popped" it back in place it was all good and no more indicator light.
Hang in there, it may still be a bulb deal. There is a comparator that monitors the current load of all lamps in the circuit - when operated. So, if you turn on the headlights does the error lamp trip? Does it trip when you step on the brake? The selected function will tell you which set of lamps has the failure. Roll through the parking - headlights - brake slowly and watch for the trip.
The bulbs of course have to work but they need to be the absolute factory value. Current higher or lower than the original value will trip the light. Shadow points out aftermarket headlights may trip it as the load changed.
The third brake light is often overlooked. My car had too bright of a lamp in the third brake housing. It was a 1156 some owner thought would be fine as it fit. The factory called out a different number. Switched the bulb, error light stayed out. It would trip the first time you touch the brake after starting.
The guy said to get the voltage regulator checked on my next service and I'm fairly confident that’s why my warning light turns on and off while driving.
Worth a look rather than hiding the problem.
I had my radio going on and off... ended up opening up the fuse box (under the fuses) and checking all the wires and all that mess. Jiggled stuff around, figured out wich wire it was.. cleaned, tightend... works all the time now.
my light indicator does that too though, but not allways... ive learned to ignore it.
hmmm. . .
Lui
I do have one front fog light burned out and I have the part ordered. Once I get that replaced and check the third brake light I'll have to troubleshoot further if the problem still exists.
