Getting a 300TE, have a few questions
I have seen a few write-ups on upgrading sway bars so I'm not concerned about that, and I am not too worried about having to do some work since I do have experience working on cars. However, as I have zero experience working on w124s, I have a few questions. I hope they aren't too simple or easy to answer.
My first question is concerning using lowering springs and dampers designed for general use on a 300e, etc. for use on the wagon. I have seen products, both springs and dampers, that indicate they will work on a CE and E, but leave TE off of the list. I have done some searching but couldn't come up with a definitive answer. Is this simply because they don't perceive a market for wagons or because of some physical difference keeping the wagon from using those parts?
Thats the main question, but I was also curious if there are any aftermarket differential options for this car?
I'm really looking forward to getting the car. There are a few local cars I am considering right now and I plan on making a decision and purchasing one within the month.
Thanks in advance.
Regards,
Rory
Start on the suspension by checking bushings and bearings... install some good Bilstein HD shocks which you can use if you decide to lower it... but a 500E swaybar is a good start too. The first step is to have a good base to work from.
Show us some links of the TE's you are looking at.
I am looking to get a new diff for my TE, the 190 16 valve diffs fit, and have posi traction.
I also have parts from a 190 to do a stick shift conversion... oh lordy.
A manual conversion would be awesome, an automatic is something that I will have to get used to. I had considered a 190e, but decided that i would be too apt to modify it, particularly since my buddy has an awesome cosworth equipped 190e.(I forget the proper designation)
I will have to look at a 190e diff, thanks for the info. Do you know if there are any aftermarket clutch pack differentials for those pumpkins?
Thanks for the info.
I'll post up a couple links to what i've seen locally tonight or tomorrow.
Ideally I want a 93+, but I'm not super picky, just want a straight car with a good interior thats mechanically sound.
This looks clean from pics, decent price, though no mileage is provided. I can live with the white and beige interior, so its at the top on my list for now.
http://seattle.craigslist.org/sno/car/457880792.html
Heres another use car lot car. It is a 93, but has higher mileage and is red, which i have very mixed feelings about. Its one that I will probably check out though.
http://seattle.craigslist.org/see/car/452080329.html
Heres a car in spokane, id call before driving or flying out there, its a 94, priced at $5500, but looks damn clean. I dislike the blue interior a lot, so i'm a bit disappointed about that but if the rest fall through I may consider it despite the interior and distance.
http://spokane.craigslist.org/car/448437459.html
There are a couple other seattle area TEs that are listed in craigslist but provide minimal info and no pictures, so until I call these are whats worth posting.
Any input?
By just changing the spring pads, you could lose close to 3/4s an inch in the front and maybe a 1/2 inch in the rear if also you adjust the suspension level correctly. Yes, you would also want HD shocks up front. The rear hydro-struts usually are long lived, usually. Make sure you check the rear out on whatever car you want...a failed/failing system can be expensive and a PITA to fix, but when they are working up to snuff they are nice and easy to maintain.
Search mercedesshop.com archives for all sorts of technical info on the SLS (self-leveling suspensions). Trouble I had in finding a good wagon (I didn't and gave up and bought a cabby) was that they ALL pretty much wear/look very well; its the maintenance (or lack-of) that ruins any deal to be had.
The Sportline Option for the W124 wagon was never offered in the states (just the sedan and coupe), but the parts can be ordered. I had the OE Sportline suspension (sway bars, dampers, springs, bushings) installed on my 300CE and was a really enjoyable improvement. Even after 5 years of daily use, the suspension held up very well. The car always felt very "planted".
I sold the CE this summer in favor of a '95 E320 Wagon which I'm slowly making changes to. First up is maintenance and repair.
Since picking the car up in late July, I've replaced both wiring harnesses (engine and starter), interior dome light assembly, new lower control arms and rear control bushings, changed fluids and played around with a few cosmetics - tinted windows, replaced the wheels and tires with staggered AMG Monoblock IIs, and had the car lowered. The car is well-suited for baby hauling and daily driver duties.
I've still got a fairly long list of things I want done - but will get to them as time (and money) permits. I've got a small exhaust leak b/w the muffler and cats, the sunroof opens but doesn't close, the blower motor fan was installed backwards (we believe), I'll upgrade the speakers to Rainbows, and then get serious about making some suspension improvements....all the while making sure the scheduled maintenance is performed on time. This doesn't include any necessary repairs that may come in between.
Whatever you do....if you want to play with the suspension, do not get a 4-matic.
straight from the factory) in order to contrast things a bit...I was thinking about doing black interior door panels but taking those things off ARE A PITA!
straight from the factory) in order to contrast things a bit...I was thinking about doing black interior door panels but taking those things off ARE A PITA!I like the white wagon best in the three listed, but an in-person inspection would reveal. I looked at several wagons before finding mine.
It scared the crap out of me actually, to see the back of my car lifted a good 22 inches or so of the ground!
I bled the system and luckily for me it came back down, but now the right side of the car sits a few inches taller than the left side
Any hints???
by all this...I'm going to have to show pix somehow...
see what I did was I basically move the rod back and forth a few times, so perhaps what I was doing was shortening it??
i guess I shouldnt mess with it if I DONT know what I'm doing
Yes, this adjustable rod, when as connected to the swaybar moves the lever on the SLS which in turn fills or emptys the 2 hydrualic cells with fluid therby 'pushing up' or 'lowering' the fluid in the struts (which are really just hydraulic pistons)...so when there is weight in your rear end, the rod that is connected to the swaybar moves the lever down on the SLS ; opening the flow of fluid causing the system to fill which raises the rears height. Adjusting the length of that adjustable rod in relation to the swaybar is what sets the ride height. Making it longer lowers the car and vice versa. Just moving the SLS lever actuates the system, yes, it doesn't permanently change the ride height; adjusting the length of the 'turn-buckle' connecting rod is what will change the ride height. Does this help?
There is a section on the MB W124 CDs from the factory that explains this system also. Let me see if I can find a link to it. Pix worth 1000 words they say right?
makes a hell-of-alot more sense now! Thank you so much Jim!
Pix would be awesome!!!!!
This is the rod that you need to take out, lengthen 3/4-1" to get approx 1/2" of lowering, then re-install...if you look under your car from behind the right rear wheel, you'll see this lil' sucker...one end is connected to the SLS valve, the other end will be connected to the swaybar. I think its like a 10mm and a 6mm wrench to get them off....not hard at all but clean the area off with brake cleaner...it will be easier.
Can't seem to find the W124 factory CD SLS section yet online, might have to get it from home CDs...or I'm sure someone else can unload/link to it for you.
So I guess I have to look for the link on the swaybar correct? to connect it back again right? that's really weird...
When connected up you can't move the lever at all, obviuosly, when the car is under its load.Just buy a new one from the dealer or WorldPac for about 30 $ ...it'll have the correct end bolts included...put on some loctite while you are at it. 5 minute install at most.
Yes, you should see where the top of the rod connects to the swaybar..if its still there !
but what i'm reffering to is that my rod is connected to the "pump" I would assume? not the swaybar itself.
So you see it's sorta in the middle of the undercarriege of my car, not the swaybar.
does that make sense?
Yes, I understand now that the rod is still present on your SLS lever controller but not connected to the swaybar. Your pix will explain it all I'm sure. Curious to see the swaybar and the connection point there if you can snap a shot of it.
