Dam Rattling
Old Oct 31, 2007 | 12:09 AM
Geh's Avatar
Geh
2007 GL500, 2007 E280
Dam Rattling
Ok i have this annoying rattle on my Merc When i put it into Drive you can always here this loud rattling when accelerating it goes away or when its in park. Its so loud when i stop at lights i can here it inside the car even when i have the radio going
Ive found the part thats rattling when i put pressure on it the rattling stops, i just need to know how to fix it?
Please help????
Attached Thumbnails Dam Rattling-merc-rattle-1.jpg   Dam Rattling-merc-rattle-2.jpg
Old Oct 31, 2007 | 12:17 AM
ZedStyle's Avatar
Youngtimer
i have a different engine and it's dark so i can't see properly if i have the some thing on my car, but from your pic it looks like there's a bolt there, maybe try to tighten it?
Old Oct 31, 2007 | 12:26 AM
Geh's Avatar
Geh
Yeah i tried to tighten the bolt but not luck she still rattles, Would you have any idea why it only does it in drive and not park???
Old Oct 31, 2007 | 12:33 AM
markmam1's Avatar
W203 C230k '05
yeap I had that one too, its a biach to replace but I still did it after 4 days rattling came back so pist that I just quit. It rattles because the bushing wears out pretty quick. I remember when I replace it took it out and for like 2 days never drove with it nothing happened but I put it back just in case.
Old Oct 31, 2007 | 12:43 AM
ZedStyle's Avatar
Youngtimer
maybe take out the bolt, and put a small rubber washer on the bolt and tighten it back up?
Old Oct 31, 2007 | 12:45 AM
Geh's Avatar
Geh
I hate it so much its just so annoying knowing that it rattles, and i hate when im sitting at the lights and people have their windows rolled down and they give my car dirty looks
If only i had a bullbar
Old Oct 31, 2007 | 12:48 AM
Geh's Avatar
Geh
Sounds like a good idea ill give that a try, ill do it tomorrow ill pick up some rubber washers while im out
Old Nov 2, 2007 | 01:52 PM
appatula's Avatar
95' AMG SeeThreeSix
I had the same issue, I cut a 1/4" washer out of wood and put it on the bolt and tightened it up just enough. The rattling never has come back since and its deff been over 1k miles. Its called the engine shock damper if i remember correctly, I picked one up off of ebay for 25 bux shipped but after I saw how much of a ***** it would be to R&R I began the procrastination
Old Nov 3, 2007 | 10:11 AM
Geh's Avatar
Geh
At this moment anything will do i just want rid of that awful rattle, i've been procrastinating too i was supposed to go and get some rubber washers......
Lets just say i keep "forgetting"
Old Nov 3, 2007 | 11:14 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Have you tried adjusting it? Looks like there's a tension adjustment.
File Type: pdf
Old Nov 3, 2007 | 01:12 PM
White_Knuckles's Avatar
1994 E320 Dragon Wagon
Wood may work but wouldn't be my first choice. Adding rubber washers sounds like the deal. If disassembly presents a challenge you could cut the washers and slip over and tighten.
A blob of clear silicone may do the magic after cleaning the bugger with some brake cleaner. Ahhh, fast and dirty ... my favorite.
Old Nov 3, 2007 | 02:05 PM
Lancelot's Avatar
'01 W210 E320 CDI
The part you've pointed out in the picture is a Belt-tensioner/damper. I would not mess with it and get it replaced and/or your belt checked out as well. It's a sensitive part on W124's and I had it replaced twice on my W124's...
Old Nov 3, 2007 | 10:27 PM
Geh's Avatar
Geh
Any idea how much this is going to cost me
Old Mar 1, 2008 | 05:09 AM
Geh's Avatar
Geh
Finally Got Around to Fixing the Rattle on my Benz :P
Rubber O-rings work a treat haha
Old Mar 1, 2008 | 05:54 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
if my car rattles it means 3 things. 1 fan shroud came lose again and is hitting the damb belt or the fan its self .2 the door molding came lose again or my favored one is number 3.... that is a ***** to fix normally it means the frount light is trying to come lose again. other than those problems i dont have much wrong with my car any more. most are little 10 or 50$ parts that are easy to fix and rebuild... i hate haveing to take stuff out and take apart to fix or rebuild to get a little more time out of them..such as my alternator. works better but i still bit my lip hoping it would work im hand with some stuff but bad with others
Old Mar 1, 2008 | 01:25 PM
berti_00's Avatar
2016 Cls63s AMG
well if its ratteling than its DONE... my brother just replaced his. you cant take it out and clean it or any thing its a replacement thing. i remember when his was doing that... it was annying as fuc.k ... but just get one on ebay and replace it...
good luck
Old Mar 1, 2008 | 05:56 PM
berti_00's Avatar
2016 Cls63s AMG
here you go buddy
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
Old Mar 1, 2008 | 10:24 PM
ksing44's Avatar
2010 VW Golf TDI
Ahh, don't fix it. Just turn up the stereo.
