Calling ZORRO...
Old Nov 17, 2007 | 08:34 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Calling ZORRO... [Pix Inside]
crappy pics of new updates.
Didnt quite get my clearcoat on the tails yet but it's definitely on the list.
anyways....chop me a sig would ya
http://i9.photobucket.com/albums/a68...e/IMG_5565.jpg
http://i9.photobucket.com/albums/a68...e/IMG_5567.jpg
http://i9.photobucket.com/albums/a68...e/IMG_5568.jpg
http://i9.photobucket.com/albums/a68...e/IMG_5570.jpg
Thanks in advance if youre up to it. If not then...whatever
Old Nov 17, 2007 | 08:51 PM
YNVDIZW124's Avatar
lots of cars
Did you use nightshades? You should remove the tint from the bottom half of the tails, just use some denatured alcohol and it won't damage the plastic. I used duplicolor metalcast in smoke to paint my tails but it comes out more grey than black.
Old Nov 17, 2007 | 08:56 PM
Yeah I used niteshades. Cheap stuff. I think I actually just didnt use enough clear. I actually planned on taking it off the bottom half and polishing it out as well as possible. It looks pretty cheap.
Old Nov 17, 2007 | 09:38 PM
YNVDIZW124's Avatar
lots of cars
You can't really clear coat nightshades because the clear will F uc k up the paint. Don't use any kind of thinner or polish to take off the paint. Like i said use denatured alcohol and it will leave them like new. I painted my tails like 4 times and remove the paint with that.
They used to be painted all red but now they are grey. I couldn't get a good picture but here are mine...
Old Nov 17, 2007 | 09:43 PM
Did you sand first? Thats half the reason Mine look the way they do, because I sanded with 100 grit beforehand....
like this guy
Old Nov 17, 2007 | 10:00 PM
YNVDIZW124's Avatar
lots of cars
Nope, no sanding. I would have sanded mine if i was going to paint them with a black clear coat. I can change mine back to stock just by removing the paint with alcohol. What i did was to degrease the plastic and just cleaned them with a tack rag. I used duplicolor metalcast smoke paint and gave it very light mist of paint to make the first coat stick. After that i just counted the coats of paint to get an even color on both tails. Once I let them dry i just use rubbing compound to make them glossy.
Old Nov 17, 2007 | 11:05 PM
YNVDIZW124's Avatar
lots of cars
I was bored so i shoped one of the pics...
Old Nov 18, 2007 | 02:40 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
wow thats sick looking
Old Nov 18, 2007 | 05:39 AM
ZorroAMG's Avatar
Enzo, my Benzo
The mistake was the sanding....you cant possibly sand the grooved tails like that 350Z.
You need to CLOSELY spray (3 or 4 inches away max) the clear on THICK.
I'll chop your pics tomorrow for a sig
