230CE is killing me - HELPPPPPPPPPP
Old Dec 12, 2007 | 07:10 AM
HaithamMercedes's Avatar
230ce 1989
Question 230CE is killing me - HELPPPPPPPPPP
hi all,
i am new memebr,
i really need help,
i have a 230 CE coupe mercedes,
the engine dosent start from the first time, i need to try six times then the engine start,
the car is very havey when i drive it, no kick down action,
smell of petrol from my backseats!!!!!!!!!!!!
when i look under the hood its a miss, disconnected wires and vacummes pipes, missing pipes ,
the thing that make me really angry is that the engine is fitted with new internal and gaskets, fully overhalled!!!
i also have some backfire some times,
buffffffffffffffffffffffff,
really need ur help guys,
i also tried to get the repair manual for my car, but i always get the same **** magazine every time i download it
Old Dec 12, 2007 | 07:12 AM
Geh's Avatar
Geh
2007 GL500, 2007 E280
Welcome to the forums
hope someone can point you in the right direction
Old Dec 12, 2007 | 10:44 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
Sounds like your MAS unit may be going bad. My car acted the same until the MAS finally died.
Old Dec 12, 2007 | 01:52 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
first off, bring the car to a benz mechanic to get all those vacuum tubes and such replaced, im sure thats causing quite a few problems if i had to guess. also, you can adjust your bowden cable so as to make the transmission a bit more responsive to the gas pedal
Old Dec 12, 2007 | 04:01 PM
124-Fan's Avatar
Mercedes Benz
It´s always a good thing to check the basics. How old is your fuel filter, plugs, rotor, cap and leads.
Your OVP might also be bad. And the smell of fuel doesn´t sound right. Is your tank leaking or is there a leaking fuel line perhaps.. ?
-The tank is located behind your rear seat and accessed from the trunk. You must remove the panelling to see it properly.
Cheers,
Old Dec 12, 2007 | 09:46 PM
STLe320's Avatar
95 e320...sold the rest
How would you go about adjusting the bowden cable on a m104 motor?
<edit> Didn't mean to jack the thread, but I didnt think it was necessary to start a new one..
Old Dec 12, 2007 | 10:04 PM
crr1612's Avatar
its right under the airbox...take it out and tighten to increase responsiveness and raise shifting points; and vice versa
Old Dec 15, 2007 | 11:04 PM
230ce 1989
thanks guys
Old Dec 16, 2007 | 12:21 AM
bjay51d's Avatar
1989300CE(sold),1996Accord,02CBR954
jump ship
Old Dec 16, 2007 | 12:26 AM
YNVDIZW124's Avatar
lots of cars
I had a 230E here in the U.S., let me ask you something. You have a 2.3L 4cyl engine right? You should be able to get parts from a 190E for the 2.3L engine.
I think you can also get help on the 190e section since i'm sure there a lot of people with the 2.3L engine.
Old Dec 17, 2007 | 12:24 PM
shadowgriffen's Avatar
is a German Tank
Originally Posted by bjay51d
jump ship
Lol
