Anyone done staggered 17" wheels on an early W124?
W124
Hi:
Has anyone installed staggered (7.5x17" & 8.5x17") wheels on an early, '86-'89 W124???
Thank you!!
Thank you!!
W124
lots of cars
Actually, I did and found nothing clear & definitive for the early cars,...
W124
is your car lowered? If it is, it limits the width of the rear tires you can go with - unless you have the fenders rolled...
I had 245/40 section rear tires with no rubbing on my coupe - but I did have the fenders rolled.
W124
Its at stock ride height to deal with a VERY steep driveway. Fender lips are not rolled but I think I'll stick to the same front & rear wheel/tire combo to keep the tires tucked into the fenders a bit. That helps keep the schmutz off the rocker panels in our inclement weather here in PDX.
1987 300E
those are amg 18s stag and the fronts rub like a ***** espically with more than one person every dip in the road. n if ur from south jersey forget about rollin the fenders NO ONE does that **** i have probably called hundreds of people. im think bout replacin the shocks see if that helps firgure it cant hurt since they are 20 years old
Both worked fine...but as Zedstyle had pointed out my rolling circumference was off a bit with 215.
By the way guys, I autocrossed my W124 at a PCA autocross event where we are supposed to bring our non-Porsche cars. It did fantastic and handled well. No rubbing under lots of full suspension compression....this is the main reason I down sized the rubber. It may be only 10mm wider BUT the much stiffer and shorter sidewall sharpens the handling infinitely. I was able to bring the tail out nicely in controlled drifts around the cones. I have Bilstein SPORT shocks and HR springs.
