Limited Slip Differentials for W124's??
My best guess at this time is that I need to find an open diff with the gear ratio that I want (2.82) from an S class (a 210mm diff). I then need to buy the carrier you suggested and install it. Am I on the right track now. Thanks again.
Now, as mentioned before... the clutches on a used S350 ASD diff are likely to be pretty worn. You can either take a gamble that they still have some life left in them, and try it out... if there's not enough locking action, you'll need to take it all apart again to replace them. Or, you can just plan on refreshing the clutch pack at the same time you're swapping the flanges & cover. Figure $300-$400 in parts for the refresh, you'll need to make some tools, and figure out how to do it... not terribly hard but the first time took me forever because I didn't know what I was doing. My second attempt went about 10x faster. The W126 service manual has a really good procedure, job # 35-550, which details how to take the diff apart to get the ring gear + carrier out so you can then disassemble it to replace the clutches. Then, job # 35-560 shows how to take the carrier apart and replace the clutches. Forget the 124 service manual for this work, it's not nearly as clear.
Oh, and be careful with the ABS sensor... you may need to swap that also, and they can break if you're not careful removing it ($$$).
For a car with ASR, this won't work, the housings are different. My E420 has ASR, so I have to do it the hard way if I want to add limited-slip).
Best regards,
If its anything more involved then it depends on how extensive your collection of tools is, and how adequate your ability is.
Normaly you needen't change the pinion or the input flange, cause they are mostly ok.
You yust change the 6 bearings and sealings.
In my ALSD I just replaced the stuff shown on the pictures below.
You just need some normal tools like wrenches, hammer and chissel for changing the bearings, a flex and and of course i used a few extractors to bull some of the bearings off, but you can also use a flex for the job.
The new bearings can be mounted by hand if you put them on a cooker, before. You may have the right big nut for the front screw nut.
The setup of the clearance can be made by feeling.
You don't need a tool for reading the pinion friction moment, because the min was by ca. 40NCM and the max at 100ncm, i think, so thats what you can feel with your hand.
You also needn't a mounting plate, yust put it on the table.
You needn't a tool to pull out the circlips, you just can use a wire or a gripper.
Instead of a Puller, you can use a hammer and chissel to pull out the driveshaft center support bearings out of the body and to pull the new one in. You just mustn't hit the bearing surface...
Right here, you can see my story of rebuilding my diff, sorry, but it's in german and it can be that you must register before you can see the pictures: http://www.mb-freunde.de/vbulletin/s...ead.php?t=3695
I got a diff from a S350 with ASD, no ASR. I had my buddy check the vin, and according to the vin, the car was a 1994 S350, ASD, no ASR. The diff has the ASD plumbing and axle flanges. So everything looks right, except when I turn the output shaft. This diff does not behave like any diff with an LSD carrier that I have experienced in the past. If I hold the input shaft from turning, and turn one of the output shafts, the other output shaft rotates in the opposite direction, just like with an open carrier. I know the clucthes could be worn, but even if they are toast, under no load it should still lock up. Did I get an open carrier? Am I missing something? I haven't removed the ASD flanges yet, but I can't wrap my head around that being the issue. Can you enlighten me?
Best regards,
Short answer: That's normal - nothing to be concerned about.
Long answer: I found the same thing when I got my ASD diffs. At first, I assumed this meant the clutch pack was shot. After replacing the clutch pack, it was TIGHT, I couldn't hold one axle flange while turning the other by hand. AH, much better, right? But after only 100-200 miles of driving, it was back to how it felt before! I could turn one rear tire by hand and the other tire would turn the opposite direction, just like an open diff. However - the difference is, with LSD / ASD, it takes a noticeable amount of additional effort to turn the flange (or tire) by hand, compared to an open diff. That's due to the clutch pack - even though it's not locked, it does create *some* resistance.
Despite how it feels by hand, the LSD function does work fine when driving (assuming the clutch pack is not excessively worn). The reason is, the Mercedes LSD design requires torque input, and load applied, to compress the clutch packs. My buddy at the dealer (who has done many LSD rear ends) explained this to me, and although I was skeptical, my hands-on experimenting proved he was correct. The bad news is, there's no way that I know of to reliably check the clutch pack condition (on an LSD diff) without driving the car to test it out (or, tearing it apart & measuring the wear on the clutch discs). Note that on vehicles with ASD, there is a procedure to measure via torque wrench, but that's not possible with plain LSD.
So, you're back to decision time... either bolt the used diff up and hope the clutch pack is ok, or just tear it all apart and spend the time & $$$ now, before you install it in the car.
**Even better, if you are converting an ASD diff to LSD (which is what I did), no adjustment should be required, since you are using the factory-assembled housing, ring, pinion, and carrier. This is what I did for my 185mm LSD (I just had to take it all apart to refresh the clutch pack, and re-assemble with different flanges, none of which affects the backlash or preload.) **
My 210mm setup will be more complicated since I am changing the carrier (but retaining the existing housing, ring, and pinion). I will have to measure backlash before taking it all apart, and make sure the backlash is the same when I re-assemble it with the new LSD carrier. I should have more details in a couple of months. I've talked to two different MB techs who have done this and they tell me it's doable with standard rear-end tools.
It's highly unlikely the dealer would have the necessary tools, but you can ask. Motorwerks in Houston or Austin is capable of this job, I had inquired previously about the cost to have them do it, I think it was <$500 if you supply all the parts... but that was a couple years ago, and I could have the price wrong!
it means*just changing the output flanges* and maybe the input flange
if isn't the right size . I am having the option for a W 124 E 320 Auto 3.07
ratio with ASD that I would like to take place in my C 43 AMG .
IF,, I can do that without complicate things by also build some sort of
hydraulic system to activate the ring-cylinders manually , and * just *
re-load the carrier with new friction discs and adjust the preload . WOW
In this case ( the C 43 ie ) I do not even have to care about ABS because
the diff casing is * clean * no sender's as they by MB then wisely were located
in the wheel carrier's . Unfortunately this is not applicable on the ASR
equipped car's .
The 210 mm Big diff housing as on my 500 E needs another conversion as you
say here and in 500Ecstasy namely the W 126 LSD carrier ...Period
Thank you Dave for your work and for showing , by now I'm convinced and
see the W 140 2,82 ASD as a dead end street , too elaborate to convert .
About the * feeling of an open diff * as mentioned in this thread and the
locking action under power must be the effect of the pressure the diff.carrier gears
have on the side gears as they under power * ride * on the side gears and
pushes them outwards to further pressurise the clutchpack. You can say
it has some kind of * power lock or positraction * not only working by
it's preload . Thanks again Dave . Roger
car that didn't have it from new . Either convert it to LSD as Dave did
Or like in the thread of 500Ecstasy.com Limited slip or not , matsalle76
wrote about one ASD with a manually operated system , http://www.500ecstasy.com/forums/att...5&d=1236109861
I would myself if possible go converted 185mm ASD for my W202 C 43 . Roger
Another option to increase lockup is to install a spring block between the side gears, like Kleeman or PhantomGrip, which sort of simulates ASD engaged all the time, and can be adjusted slightly by using stronger or weaker springs. The drawback to this method is first that nobody currently sells a kit for MB LSD or ASD, so you'd have to have something custom fabricated; and second that you cannot use the circlips which lock the axle flange into the diff - the axles will always float in & out. A few people have done this (mostly the 190E-16 crowd) and say it works ok, but I still don't like the idea of not having the axles fastened into place.
It would be neat to install a set of manual pedals and hook the clutch pedal up to a clutch master cylinder. Then use the pedal to apply pressure. Gotta think about this a bit more, but in the mean time, I think I will do as AMGDave suggests: I will just remove the ASD, save it, and see if the LSD satisfies me.
I do not understand, why the simple spring method between the side gears is not good?
Maybe someone could describe it to me in simple english
Thanks in advanceRod
ASD and how much operating pressure it has ?
If it's possible to set the ASD to LSD preload and then have the ability
to almost full lock if needed by operating the ring cylinders manually ?
To have a Manual Sperr Differential MSD that would be nice occationally
maybe operated with compressed air ? I don't know just a thought.. Roger
You could set up a "manual" locking diff using various methods (some are mentioned earlier, IIRC) but I still don't think you'd find much use for this. In a straight line (i.e., launching the car) you don't need a lot of lock. On a racetrack (road course), you don't want too much lock or it will cause erratic handling under hard cornering (possible oversteer).
For most applications, normal LSD is usually fine, perhaps adding a spring block if you *really* need additional pressure.
If you make more NM, it will slipp.
When it is older, it may slipp at less NM, fex. at 80 or 60NM.
The Spring idea can work. But you has also to install a bearing for it. But it is a nice idea
I am trying to determine how to correct my speedo. I guess there are correction boxes that can be place between the sender and the gauge? But I was thinking I should just get the right toner ring for the speedo sender on the tranny. Any thoughts.
Thanks to those that provided info for this mod, especially AMGDave.
Dakota Digital: http://tinyurl.com/78hvf
Yellow Box: http://yellr.com/
Thanks for the links for the speedo correction. I'm on that now.
Yes, the metal things which sort of seem like gaskets, are actually precision spacers. They are available in thicknesses from 0.90-2.60mm. You change the spacer thickness (i.e., add 0.10 to left and remove 0.10 from right) to adjust the backlash, it moves the ring gear closer or farther from the pinion gear. Same idea for bearing preload, but you add or remove the same amount from both sides (i.e., add 0.10 to both sides to reduce preload, or remove 0.10 from both sides to increase preload).
Hopefully the shims on both diffs were of similar thickness, in which case it should work out ok. If you ever have it back out of the car, it wouldn't hurt to check the pattern on the gears, for grins...
The W140 speedometer isn't the same, AFAIK... don't think it will work in a 124 cluster. It would have the same problem as a 500E speedo, although it's calibrated for 2.82 gears, the W140 (and 500E) use larger tires, so it would still be 3-4% off.
I think I would like to explore this route if you wouldn't mind passing along the info. Thanks once again. BTW, what should my next upgrade be? Maybe I should start a new thread for that.
