steering wheel groan (inside car)
Old Jan 3, 2008 | 04:00 PM
g2group's Avatar
my steering wheel has a groan to it when I turn the wheel
this is definitely INSIDE the steering column
has anyone encountered this?
i want to address this, it sounds cheap....
Old Jan 4, 2008 | 02:03 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
I've heard it sometimes, seems to only be on left hand turns. I know nothing about it however
Old Jan 4, 2008 | 07:44 AM
shadowgriffen's Avatar
is a German Tank
check your power steering fluid level and make sure it's on par.
Old Jan 4, 2008 | 10:31 AM
g2group's Avatar
the sound is like a rubbing sound inside the steering column
maybe i just need to take it apart and clean it up....
Old Jan 4, 2008 | 02:57 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
If it is a groan, that means that you have air in the power steering fluid. This fluid should always be checked and the filter should be changed if you have never done so... most people don't realize that there IS a filter in the bottom of the reservoir.
The sound that you are hearing is most likely a contact sound in the steering column. I would remove the bottom dash panel below the steering wheel and inspect the shaft and surrounding parts to look for wear.
Old Jan 5, 2008 | 12:03 PM
floodkid's Avatar
1986 300E
Didnt think this problem was a big deal.. i get it usually in the morning after a few turns its all good though.
Ill have to add that to the list
