Interior Lighting Question
Also, are there any out there in a bright blue, or white without being LED?
Door lights are 36MM
There are bright blue/white non LED bulbs but the don't look as good. Personally, LED = FTMFW!
What is your reasoning for not wanting LED bulbs?
SOrry that might not have made sense. But where can I get the blue/white bulbs for the dome/maybe puddles?
Do you have a writeup with photos and itemized parts list of this surgical procedure? Me wannnnna do...
They make them for dome and most socket types you can imagine. They use lower current than incandescent so for turn/stop applications will throw the dash, lamp failure indicator. The system sees an improper load.
The white lamps need to have several LED's clustered to produce equal or greater output. I'm betting the industry will move toward them for all factory lighting. Then they can hose us with dealer only modules.
The good - low temp, low current, long life and bragging rights. They react much faster then conventional. Good for brake lights.
The bad - color spectrum is different. White and blue are getting better but you know the "white" from those flashlights everywhere.
http://www.ledlight.com/LZAuto.aspx
MARKY, I don't have a write up but to clear things up I just did all the bulbs and I'm still working on changing all the switches to LED's as they are all still stock. I bought all the extra switches to do the swap but just havent found the time and I'm still lazy.
Do you just want pictures of the LEDs installed and links to where I bought the LEDs?
details on how to do the switches.
theres also a few threads on this.
plain on doin mine red, waiting to find some extra lights from a junkyard to make sure i dont mess mine up.
although i do have a broken one to play with when i get the time.
t5 led for the swtiches
t10 led for the instrument clusters
39mm festoon led for the trunk, and interior
36mm festoon led glove box and map laight, doors...i think
39MM for the Trunk and both interior dome lights.
36MM for all doors.
the small map light is a little bulb but I forget the exact size.
TO answer your question, your factory US headlights should be 900something and euro lights like factory euros or my projectors will be Hsomething
(H4 factory, H7 projectors)
