Wheel Fitment Issues
Thanks!
i'm going to try, we've got guest from around the country coming over to my house this weekend, so i won't be able to if it's on sunday.
hopefully it's on saturday (am-early pm works great for me)
having said that, people put the s class wheels on all the time, so i'm not sure what happened with yours... did you see where they were rubbing against the suspension?
Ah ha, I didn't know it was the S that got the 16s and the w124 still had 15" versions of these... Although still I guess it should fit.
These are the exact wheels I'm trying to fit:
http://orangecounty.craigslist.org/pts/501301878.html
They're wrapped with Conti 215/55/16s
thanks again
Edit:
Okay this info should help, I don't know what the offsets are but:
These are the current wheels I'm running:
Which are 16x7.5 also..
Looks like the w124 versions of the 8-hole were 15x6.5, however if a 7.5 width already fits shouldn't there be no problem?
I got the info and pic from here:
http://www.wheelcollision.com/merc6.htm
Anyways, It's on Saturday and starts at 12PM and will probably go until 7PM.
It's in Santa Ana on Westminister and Harbor. You have my number and Aim - hit me up for more details.
BUT, the good news, is that Saturday, I'm scheduled to take delivery of my W204 I ordered way back in November 2007. =)
I don't know where I put your number though, IM me w/ it. Thx.
I am wondering about rubbing on fronts. How "close" are yours?
Can't take car for test-fit, unfortunately.
BTW - side note about using S or SL wheels on a W124... those cars use M14 bolts, with a larger ball seat. I would strongly recommend using M12 bolts (needed for the 124) which have an M14 ball seat (needed for S/SL wheels). They are available from RAD USA Direct in assorted lengths (you'll need to double-check the length you need also.)
Yes, I was worried about rubbing with my 35 offset.
Out of curiosity, what is the offset of your wheels?
Also, TireRack recommends a 245/40/18 tire. Do your 255's fit better?
What is the difference in actual outside diameter between 245's and 255's? is it negligible?
About tire size, the originally had 245-40-18 tires on there. But I got a good deal on a set of 255's, which were factory fitment on the new SL600, on an 8.5 wheel. Either one fits fine, but don't go any smaller than the 245.
In the rear I have 18x10.0 with 285-35's, had previously been 275-35... same reason as the fronts, also from the SL600 wheels. (I've got the 2007 SL600 wheels for sale, if anyone is interested btw... rears are 9.5 wide.)
Many thanks
Yeah, you could, on the rear end of a E500...but like AMGDAVE said, nothing larger then 8" wide will fit the standard w124
