--Dash lights question???--
Old Jan 31, 2008 | 03:49 AM
berti_00's Avatar
2016 Cls63s AMG
hey seems like my dash lights are kinda dimmed out perhaps i've got afew burned out.. anyways i saw a w124 that had all the lights changed the dash, the front instrumental buttons such as a/c and such and down here at the shift knob and the window buttons into blue???? soo are they all the same as the dash board lights
check these out and tell me wuts up
http://cgi.ebay.com/ebaymotors/2-BLU...spagenameZWDVW
thanks dude's
ohh and how many does it take (bulbs)
Old Jan 31, 2008 | 04:19 AM
Geh's Avatar
Geh
2007 GL500, 2007 E280
Im not sure How many bulbs it takes on the US Versions, as The Australian Versions seem to have more Objects lit up on the front instrument cluster,
2 in the Dash, 3 in the Front instrument cluster, 1 in the shift knob Dials
And im not 100% sure if all the bulbs are the same
Old Jan 31, 2008 | 07:18 AM
ZorroAMG's Avatar
Enzo, my Benzo
Did you turn the dash light knob fully? Its the black stick under the tach/clock
Old Jan 31, 2008 | 09:47 AM
berti_00's Avatar
2016 Cls63s AMG
yah i did that i can see them dimm on and off if i twist the black round thing but its just not bright enough...one at te shift knob has no lights? dead prolly...
but am trying to figure out the blub type and if they are all the same in dash and front and down there at the knob/window buttons
Old Jan 31, 2008 | 09:51 AM
cobraperri's Avatar
The original dash lights are dim, no good. Change to a higher wattage bulb or LED. Don't go too high on the wattage or it will melt the white plastic housing.
Old Jan 31, 2008 | 11:24 AM
STLe320's Avatar
95 e320...sold the rest
What is the wattage on the current lights? And what's the highest you can go without destroying anything?
Old Jan 31, 2008 | 12:52 PM
cobraperri's Avatar
I not really sure, but I believe they're 5 watts. Get LED if you can find them. They'll last forever, won't burn anything, use very little current, and be quite bright.
They will cost a little more, but........much, much better.
Old Jan 31, 2008 | 03:31 PM
berti_00's Avatar
2016 Cls63s AMG
few questions..
1. what is the bulb number
2. if you know.. how many are there on the dash
3. are the bulbs the same for the other lights AC/, window buttons and such
4. were can i get them?
Old Jan 31, 2008 | 03:48 PM
crr1612's Avatar
Mercedes benz 1991 300ce(RIP), now an 89 300ce
ive been without a shifter light for a while. anyone know that bulb number?
Old Jan 31, 2008 | 03:50 PM
berti_00's Avatar
2016 Cls63s AMG
same here i would hope they are the same bulbs all around dash, AC console and all that bull down there
Old Jan 31, 2008 | 04:08 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The instrument cluster takes three # W3W or # 2821 12V miniature lamps which are rated three watts.
Base is a miniature wedge.
Be careful of using a higher wattage lamp as you may discolor or melt the two distribution lenses on the top of the instrument cluster.
Ed A.
Old Jan 31, 2008 | 04:12 PM
berti_00's Avatar
2016 Cls63s AMG
Ed A.
hey thanks a lot man... i appriciate it
now am only left to know what kind of bulbs does the AC compartment area take and how many and the one down at the shift knob and the window buttons.
would either of these work... or are they to powerful?
http://cgi.ebay.com/ebaymotors/W3W-A...2em118Q2el1247
http://cgi.ebay.com/ebaymotors/W3W-H...2em118Q2el1247
Old Jan 31, 2008 | 05:59 PM
forcedawd's Avatar
W124, W220 S500 4matic, W140 S500, CLS55 AMG
Berti,
The bulbs for the gear indicator and the HVAC controls are the same.
I used Sylvania 2721 (1.2 watts). There is one bulb next to the gear selector on the upper left hand side. It is sitting inside a round black plastic holder.
For the HVAC bulbs you will need to remove the upper wood trim piece by removing the 2 screws just above the radio. The bulbs will be behind 2 pieces of silver or black tape.
Sam
Old Jan 31, 2008 | 06:21 PM
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by forcedawd
Berti,
Sam
sweet dude much appreciated
Old Jan 31, 2008 | 06:57 PM
berti_00's Avatar
2016 Cls63s AMG
I came across this and i only see 2 bulbs in there but someone says there is 2 soeone says there is 3 lol what the hell
http://www.mercedesshop.com/Wikka/W124InstCluster
Old Jan 31, 2008 | 11:08 PM
RBYCC's Avatar
You are correct there are two top panel lights, my mistake.
They are W3W 3 watts.
You posted two blue lamps, one has a 5 Watt rating the other a LED.
5 watt might damage the lenses, so I would try the LED's.
The 2721 lamps mentioned for the gear selector and HVAC are also used for all the indicators in the instrument cluster.
Old Feb 1, 2008 | 01:48 AM
berti_00's Avatar
2016 Cls63s AMG
1...so recomended is the Weged one? witch is this...
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m32
2...or this
Old Feb 1, 2008 | 11:11 AM
RBYCC's Avatar
#2 looks correct as it's indicated as a W3W which is the OEM style used !!!
Old Feb 1, 2008 | 02:53 PM
berti_00's Avatar
2016 Cls63s AMG
thank you very much RYBCC... am just woundering if they are powerful and cause the board to melt like u said...
Old Feb 1, 2008 | 05:23 PM
RBYCC's Avatar
LED should be safe as they are lower wattage then OEM.
Use an incandescent at 5 watts and you could have a problem.
More watts = more heat !!!!
Ed A.
Old Feb 1, 2008 | 05:50 PM
berti_00's Avatar
2016 Cls63s AMG
Ed A.
they say :
For 12 Volts use ONLY
so i think they will be fine
