Car Won't Start!! DD need help ASAP
Old Jan 31, 2008 | 08:20 PM
02CamaroSS's Avatar
1990 300CE
I currently bought a 1990 300CE with 144k. For the month that ive had it, it runs very strong but on start up it takes about 2 tries to fire up. Then this morning went to start it up and it just cranks over and over, but no start up. 1/2 tank of gas, oil is full battery is good. Not sure where else to start. im new to the mercedes world, as you can see by my name i have a camaro sitting in the garage. Im used to working on american cars. Your guys help is very much appreciated.
Old Jan 31, 2008 | 09:41 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
What was the temp outside? Sounds like the temp sensor or cold start valve.
Old Feb 1, 2008 | 08:15 AM
shadowgriffen's Avatar
is a German Tank
check your OVP relay, might have blown a fuse.
it's located behind the watershield (black plastic cladding behind battery)
Old Jun 29, 2008 | 12:00 AM
optimizer's Avatar
TBD
hey there! I'm new to this forum and considering a 1989 - 1990 300CE. Living in Toronto it can get a bit cold in the winter so are bad cold starts a common issue with this car? It can get to -4 fahrenheit on some mornings...
I wouldn't be needing it much during the winter say about 3 - 4 times per week..
Thanks and great forum!!
Old Jun 29, 2008 | 12:02 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
I think my CE has more issues when its warm than when its cold, but that just might be my perception on the matter.
Old Jun 29, 2008 | 10:23 PM
shdoug's Avatar
Mine ('95) always started flawlessly parked outside all winter. No, I wouldn't say cold starting is a common problem. Usually it's a part that needs replaced such as a temp sensor or cold start valve.
