turn off automatic headlamp washers?
Old Feb 3, 2008 | 01:08 AM
ZedStyle's Avatar
Youngtimer
The last few days I noticed that when i turn on my headlights, the wipers/washers on the headlights activate for a few seconds to clean the headlights. Did i turn on a setting by mistake? It wasn't doing this a few days ago... any ideas on how to stop this?
Old Feb 3, 2008 | 03:37 AM
ZorroAMG's Avatar
Enzo, my Benzo
Like they are spraying on the lights or just moving? They should only spray when you spray the windshield with the lights on. I removed my wipers but you can just unplug the motors I think, unless you WANT them to work...
Old Feb 3, 2008 | 02:28 PM
ZedStyle's Avatar
Youngtimer
they're doing both, spraying and moving... just by themselves, i'm not intentionally spraying anything.
I just don't know why it started doing this now, i think i activated something somehow. weird.
Old Feb 3, 2008 | 02:30 PM
STLe320's Avatar
95 e320...sold the rest
but it wasnt doing this when you first installed your new lights?
Old Feb 3, 2008 | 03:15 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
It sounds like there's a relay stuck on. It should not wash the headlights until you press the end of the combo switch.
It's in relay box F1, relay code "D", Designation K2- whatever all that means. The document is 5 megs or I would upload it.
File Type: pdf
Old Feb 3, 2008 | 03:30 PM
ZorroAMG's Avatar
Enzo, my Benzo
shdoug to the rescue!
I'd unplug the motors but maybe you use them, dunno.
wiperless FTW
Old Feb 3, 2008 | 04:24 PM
shdoug's Avatar
wiperless FTW
Where I live, if you drive at night in the winter you better have some kind of headlight washers or you'll be stopping every 2 miles to use your Windex and a towel. Besides, they look cool if you don't have the projectors.
Old Feb 21, 2008 | 04:17 PM
ZedStyle's Avatar
Youngtimer
where is the relay? i want to hit it with a hammer or something.
now i'm out of washer fluid and one of the wipers is pointing straight up. i can get to the driver's side plug easily, but the passenger side is a b!tch... and i'm not sure unplugging them will prevent it from squirting fluid still...
Old Feb 21, 2008 | 05:01 PM
shdoug's Avatar
Here is a diagram of the relay box F1. It is relay "D", according to my diagram.
Old Feb 21, 2008 | 05:23 PM
CDP's Avatar
CDP
W124's
shdoug, In that diagram - Do you know where the relay for the AUX fan is and also the relay for the AC/heater?
Zeddy, Seems like it's a relay problem.
At first I thought you just had your lights on along with the foglights which enable the headlight wipers to go on when you use the windshield wipers but I read your question wrong. lol
Old Feb 21, 2008 | 06:28 PM
shdoug's Avatar
The Aux fan is relay C in the F1 diagram. The relay for the AC/Heater Electronic Blower Regulator is N29 on this diagram. It's hard to tell from the pic, but I think I read somewhere that you access it through the center vents. Sorry it's sideways. I don't have a real drawing program on my home PC.
Old Feb 21, 2008 | 11:26 PM
ZedStyle's Avatar
Youngtimer
cheers man, much appreciated! i'll have to take a look at this over the weekend.
Old Feb 23, 2008 | 03:55 PM
ZedStyle's Avatar
Youngtimer
okay. i took the relay out, and opened it up. I stuck it back in, and turned on the lights. I can see the relay close when i turn on the lights.
what i'm going to do is put a piece of plastic or something in there so when the relay closes, it doesn't make contact so the wipers don't come on.
my question is, does this relay do anything else, or is it just for my wipers? if it's just for my wipers, then i can either block the relay, or just remove it altogether...
Old Feb 23, 2008 | 04:00 PM
ZedStyle's Avatar
Youngtimer
shdoug, i can see you're in this thread right now, hook me up man!
Old Feb 23, 2008 | 04:12 PM
ZedStyle's Avatar
Youngtimer
in case anyone wants to see what the relay looks like inside:
this is the relay when it's open, i circled where the contact is:
this is when the solenoid closes the relay (i used a screw driver to push it closed). You can see the tiny spring that keeps tension on the gate when it closes, that pulls it back open. amazing little piece of machinery!
Old Feb 23, 2008 | 04:20 PM
ZedStyle's Avatar
Youngtimer
messed with the lights with the relay out. looks like the relay doubles as the turn signal relay too... i'm going to try to stop it from contacting and see if the turn signals will work or not
edit: okay, i lied, the turn signals still work! i'm just going to remove the relay, and hopefully problem solved!
Old Feb 23, 2008 | 05:51 PM
shdoug's Avatar
Sorry, Zed. I was just copying the link so I didn't read your post.
I can't believe it- page 163 is missing from my manual!!! That's the page that shows where those contacts feed. Regardless, according to the diagram that relay should not energize until Combination Switch S4 is closed. I think your problem is a bad contact on the turn signal stalk combo switch (S4). Although the diagram seems to indicate that this would cause the windshield wipers to also operate all the time.
Update: Found the missing page! That relay only powers the headlamp wipers/washer pump so if you disconnect it nothing else should be affected.
Attached Thumbnails turn off automatic headlamp washers?-relay-n29.jpg   turn off automatic headlamp washers?-relay-k2-2-.jpg
Old Feb 23, 2008 | 06:14 PM
ZedStyle's Avatar
Youngtimer
thanks man, removes any doubts i had in the back of my mind about rolling without that relay! now i just need to go buy some more washer fluid....!
