m103 head.... again
something like that, please correct me if I am wrong. Thanks for the info btw.
Mercedes motors are very highly engineered and are unlike a smallblock chev where you are starting with an undertuned mass of iron that any grease-monkey can add power to. Enjoy your car for what it is right now since that manual tranny is a rarity and performance piece that not many have in this country.
Yes, good advice- about the car AND presidential election! To add to what was said, the M104 has variable valve timing. There is a hydraulic actuator integral to the cam sprocket that is electronically controlled. The entire engine control system is different on these 2 engines. It would most likely be less expensive to swap cars.
Next time I'll make sure not to bother anyone with my stupid questions about how an engine works.
As for your question about M103 2.6 vs. 3.0, timing is not an issue. The M103 has static valve timing. Those heads may be interchangeable, I'm not sure. I apologize if you were insulted. You have a valid question. No one thinks you're
crr1612 brought up the idea of putting an M104 head on an M103 engine. That would be a big problem.
Two separate things we're talking about.
fear not, we were not picking on you, and I did misunderstand you in that I thought you were going to try this on your own.
friends forever?
BTW myfirstbenz yeah I guess we can be friends... but only because of our ties to the mercedes guru
ya know, since I have no idea who you are
